Dennis Leigh Henry
Hy-Lift Jacks made in Bloomfield, Indiana USA
http://www.hi-lift.com/index.html
From their website:
Hi-Lift Jacks
Don't Settle for an Imitation — The Difference is Quality
Hi-Lift Jacks: Cast/Steel, All-Cast, and X-Treme
With over 100 years of quality, the Hi-Lift Jack is a rugged, highly versatile jack that puts you in command of situations requiring lifting, pushing, pulling, winching, and clamping. Although light in weight and easy to maneuver, the Hi-Lift Jack offers a rated capacity of 4,660 lbs (2114 kg) and a tested capacity of 7,000 lbs (3175 kg).
Only Hi-Lift Jacks are made with a two-piece handle and socket design that is built for extended life. Cheaper imitations use a one-piece design that bends easily if lateral pressure is applied while lifting a load.
Our jacks are designed to help you survive in the most demanding situations – whether you are in the Moab desert canyons, the Welsh Mountains, the Amazon jungle, or the farmlands of Indiana. With a full-range of specially designed accessories, the Hi-Lift jack is just about the most versatile piece of off-roading/farm/auto recovery equipment you can buy.
When it's a heavy-duty situation, the tool had better be a Hi-Lift!
From their website:
Hi-Lift Jacks
