Hydralift hoist.
41chev coupe
Canada
I was given a Hydralift model 28 series two post lift recently. It sat for a number of years in a cold storage quonset. Started to reassemble it,and found a couple of pieces missing. The cables that run along the base and connect to the arm assembly on the other side,have two threaded sleeves attached to them. My issue is I can't find any info on what these threaded sleeves attach to. I hope someone out there has a similar unit and could post a pic of what type of nut or threaded assembly these attach to. I went to a local dealer,but the pics they had showed nothing I could use,as well as a google search. Two large nuts would obviously what would work,but the sleeves install into a plate that is larger than the sleeves. Thanks for any information.
