Hydraulic fitting storage layout
Low50s
NE Iowa
I recently purchased a crimper and some base fittings for my farm shop. But I am wondering for those who have crimpers and consumables what is your preferred way to store fittings ? I want to make sure I leave room to add a fitting if needed
I will post a picture of the setup but I’m guessing I’ll do -4 top row -6 next then -8 and start from RH to left pipe female to male then swivel then jic m to female. But I am kind of feeling like it’s not a smooth layout so just looking for input
bigfunwmu
S. MN
Our inventory person wants to sort by part number, but that's a huge pain in the *** for actually using stuff. So sort by hose size, thread end style, then thread end size.
So kinda like you do, small to big and similar styles of ends grouped to together:
Top shelf #4 hose, left to right; #2 pipe #4 pipe #6 pipe #2 pipe swivel #4 pipe swivel #6 pipe swivel... 90 deg pipe swivels, then female JIC straight, then JIC 45, JIC90, Male JIC, Male ORB, Male ORB swivel, Male ORB 90, Male OFS, Female OFS, Female OFS 90, Male BSPP, Female BSPP, 90 deg BSPP, female Japanese swivel, male DIN light & heavy by tube size, female DIN light and heavy by tube size, female DIN 45s, female DIN 45... Ends up in the middle of the 2nd shelf, and then #6 hose stuff starts after a couple feet of empty space to leave room to add stuff later.
Changes a bit on the larger stuff when the code 61 & 62 flanges get added between the o-ring face and the BSPP stuff.
The Cobbler
I sort my brass plumbing fittings by size & style basically. anything with a flare goes into a bin by flare size , even if it has NPT
same for compression . if it's all NPT it's sorted by the largest thread size
1/2 & 3/4 copper sweat fittings are in a case . odd ball & 1" are in a bin .
Sumboodie
AK
I've been in shops with enough Lawsen bins that would about full my whole garage. Just of hydraulic and pipe fittings.
I brought home probably 75lbs worth from the trash pail of 1 shop. They didn't feel like cleaning or sorting, or reusing old fittings... reducers, bells, 90s, valves, couplers, etc. Pipe and std and high pressure (10k)
L
Low50s
NE Iowa
Ya, I feel I am kind of backwards since my machine is on the far right of the bench so I plan on working from Right to Left but ya I may have to do pipe ( - size = size + size ) then swivel, and so on since I am mainly working on old farm equipment as of right now I am sticking to pipe/JIC and JIC 90's I do not have much FFOR or ORB stuff on hand but im sure the time will come I will have to add.
Maybe I should have skipped the bolt bins and went to Durham pull out drawers like Discount Hydraulic Hose does for their kits maybe it would have saved me some bench space.
Man I would love to get some deals like that. once I was lucky and got a few coffee cans worth of stuff that no one wanted to sort and I brought it home and picked away at it randomly to get it all sorted and put in correct spots. but thats something I dont have much of is reducers or pipe fittings
Whatever you do, get a label printer.
Also different coloured tapes.
from reading some PDF files of the T-400 crimper manual I did find that they offered a label kit for Eaton/weatherhead fittings. FS-1100 was the lables for the U series fittings. I thought about buying that to put where they go. I would like to get the eaton numbers so when I use a fitting I can write it down on a dedicated notepad so every so often I can make a replacement order.
L
Low50s
NE Iowa
Bolt bins work for up to #8 or #10, bigger than that and you can't fit much in there.
Ya, DHH sells kits and they use the Durham style pull out drawers but it looks like they only do = size hose ends which in all honestly would probably just fine but I go up and down a size which is most likely overkill I considered something like a lista cabinet with drawer dividers but I couldnt justify the cost since I only have about $225 in bolt bins
Jtels85
We are a Gates dealer, using an OmniCrimp 21. Ours are sorted in Vidmars, with designated draws for 4's, 6's, 8's, 10's, 12's, 16's, 20-24. Most of what we used are JIC or flat face, but we have all sorts of fittings.
L
Low50s
NE Iowa
I would have loved some vidmars. so far i have made a decent bit of hose and everything i have used is JIC or NPT but i really would like to expand just to have options
Zewnten
should be in closed bags or containers to keep clean.
No, that is what a hose pig is for. How do you plan to keep the wire hose clean after cutting it?
I use the durham pullout drawers, I have two; each one is 24 drawers I think. Big fittings take up too much room for that so for hose I have some steel bins thats equivalent to two drawers width.
L
Low50s
NE Iowa
as much as id love to have durham drawers for everything the cubbies pictured are in a heat/ac back part of my shop so the dust is minimum good enough for me. So far i have put this thing to decent use one morning my son and I went to work and made every new hose for an anhydrous bar i want to say it ended up being around 18 hoses i just figured my fittings before hand and ordered bulk fittings online.
