Hydraulic Fluid cleanup
Kscardsfan
The Little Apple
Does anyone have a recommended way to clean hydraulic fluid out of a truck bed and off the bumper? We had to transport a broken cylinder to the dealership to try and match it with a new one and it leaked out all over the bed of the truck it was riding in and has made a hell of a mess. Dawn dish soap, Carb or brake cleaner, and car wash soap have all been brought up but none of us know what would work best and what would just be ******* in the wind.
Rockable
Oak Ridge, NC
I vote purple power and pressure washer. I would just spray the bed, then spray the purple power on it and scrub it around with something like a tire brush. That should dilute it adequately but don't let it sit too long. Then, hit it with the pressure washer. It might take more than one application. Purple power is my go to for stuff like this.
elmer
Detroit
Wipe it up with a towel then oil soak/kitty litter. Wait a day and then hot soapy dawn and water.
Rockable
Oak Ridge, NC
After reading Whatego01's response, I agree. I recently bought some "Oil Dri" from Advance that is basically really dry sawdust. It absorbs oil faster than clay (kitty litter) I would use that first, then have a go with the Purple Power.
RedneckWelder
The Ghetto Kingdom of Methlandia
Purple power or similar and a HOT water pressure wash works best. Cold water will also get it done but may take a couple of applications. A brush to agitate once the degreaser or soap is applied helps too.
If whatever dealer you took it to has a wash rack, I’d ask them to use it if they don’t mind. I sprayed off many a customer’s truck bed or trailer if they asked nicely.
PCustoms
VT
I use sawdust and gasoline to clean my garage floor. It pulls the oil out of the very poorly done concrete.
The guys freaking out about a little kerosene and grease are gonna have a field day with this.....
johninct
If your paint is really good, you don't want to put any sawdust, kitty litter in it because it can scratch it. A pressure washer can cause damage too. Gently mop it out with a rag , wash it out gently with simple green mixed with water and then use an automotive paint prep solvent on a rag.
whateg01
doo dah, kansas, usa
I gotta believe if the paint was that good, op wouldn't have put a hydraulic cylinder in the bed without something to protect it.
Speaking of which, I don't know how big the cylinder is, but I have a concrete mixing tub that I use for stuff that might leak. I know they've been mentioned for other uses before, too. They are very versatile. Everybody should keep one around.
BrandonV
Arizona
Another vote for an absorbent (kitty litter, etc.) and then any degreaser/solvent should work.
I've used this combination for a leaking hydraulic elevator.
PCustoms
VT
All of the solvents mentioned are at least as flammable as gasolline. For some reason people seem to think only gasoline is dangerous.
I think you're the only one that mentioned a solvent or gas?
K
Kscardsfan
The Little Apple
Might have to find a feed tub or something similar to use in that application.
