houston_t,
I feel that the flakes help disperse the weight of jacks, toolboxes, etc.
Eric w/ GFE
i wouldn't slide the jack sideways or slide the stand either it could peel up the coating.
I respect the comments from the floor pros but find it hard to believe that diy epoxy floors would be tough enough against repeated drops or gouges from jack stands. My only expectations with diy epoxy floors would be that repairs to the epoxy finish would be relatively simple touchups and that hot tire pickup would be a thing of the past.
Why would a diy floor be any different from a pro's floor ? Granted if the diy got his epoxy from the back of Joe's Floors van maybe it would not be as good (who knows might be better without EPA and OSHA rules in it), but assuming the diy is smart and gets the quality stuff, it should work exactly the same as a pro installation.I respect the comments from the floor pros but find it hard to believe that diy epoxy floors would be tough
I find it hard to believe that diy epoxy floors would be tough enough against repeated drops or gouges from jack stands.
DIY doesn't equal lesser quality.
If you're talking about a one coat application of some sub-par epoxy applied at 3-4 mils DFT you have a point.
If you're talking about a 100% solids 20-40+ mil DFT single or double broadcast floor with a hard polyurethane you'd be surprised what they can hold up to. I see them in industrial applications all the time hold up to heavy forklift traffic, repeated dropping of parts, chemical spills, loaded pallets being dragged, chemical wash-downs and much more. You pay for what you get. Just because a pro didn't install it doesn't mean it's ****. Surface prep, proper application, and quality products make a great floor.
Prob too late to ask this now but is the kit I bought any good ?
It's not that they are bad, they just aren't a good value for your money in the long run. It also depends on what you expect to get out of one of these kits. I suggest you read this article to learn a bit more about what you purchased.
I read a couple good reviews about epoxy-coat on here and they are local to me so I figured I would give it a shot
