Badasssapper67
Anyone have any ideas on books or pdf's about how much a hydraulic cylinder can lift?
What I mean is, if a cylinder can lift 10K lbs but has a 24" stroke and you use it in a scissor lift that lifts 48", does that mean the lift has a 5k lb capacity? Also, to lift more, is it better to go with a cylinder that has a bigger bore, or one that uses higher pressure? Does one with higher pressure mean it's built better and will last longer?
There are a lot of books for sale on the net that are about hydraulics but I was hoping someone here might suggest a good one.
Thanks
Thanks
