Hi I have a simplex 100 ton press (way more then i need) and i need a longer stroke and want to replace the noisy high pressue simplex powerpack with a traditional 3000psi hydraulic system.
I dont need 100 tons, but was hoping to keep around 50t. I found a 5.125 bore x 14 in stroke cylinder in good shape for next to nothing. This will give me 31t at 3000psi which is probably more then ill ever need, but less then i was hoping for.
I've also considered adding a hand pump for extra control and feel when doing delicate work. I would run the hand pump and electric pump in parallel with a check valve in front of each. Then it hit me, i could use a higher pressure hand pump and i run the system up to 5000 psi (cylinder can handle it) and i would reach my 50t goal as a bonus. The hand pump could be used then in case of a rare occasion that 30t wasnt quite enough.
But i cant seem to find a manual 4 way directional control valve rated over 3000 psi? Anybody have any suggestions? Is there a better way to add a hand pump so i can have electric and hand control?
