Hey Guys,
I have been doing a lot of learning/researching over the last couple weeks on Hydraulics and other methods of creating a scissor lift. I want to create a height adjustable assembly table like the one pictured below..
I was hoping to get some advice and avoid any serious and costly mistakes
For the size I want, I am thinking dual scissors is the way to go. That means I either need to tie the scissors together mechanically or use dual cylinders. From my understanding, synchronizing the cylinders is going to be the challenge. I have no background in hydraulics. This is my first time learning all this stuff.
Power Unit:
I also want it to powered lift. I looked into a foot pedal deal for a manual lift and they are impossible to find and really expensive when I do find them. So I am thinking electrical with a remote pendant. The table will have 110V anyway. The problem has been finding a compact 110V hydraulic power unit, thats small enough to fit inside the lift. I can find 12V ones all day long, but I really dont' want to mess with a battery that needs replacing every few years.
I think I finally found one though...the quickjack 110V power unit
It's made for the quickjack obviously, but is 110V, has a remote pendant, is tiny, and has a flow divider/combiner built in which from my understanding should automatically synchronize the dual cylinders.
What do you think?
Cylinders
Finding single acting cylinders also has not been as easy as I thought. However, its my understanding I can take a dual acting cylinder and put a breather vent plug in the down port of the dual acting cylinder. That effectively makes it single acting correct?
End of Stroke
When the cylinder reaches its end of stroke, the pressure relief port should open and just flow back into the tank correct? Does that harm the cylinder? I would think its better to let the cylinder reach end of stroke, then have the table hit a stop and possibly bend/deform the scissor arms...probably a stupid question but I have not been able to find a definite answer on google yet.
Appreciate any advice/ideas etc!
EDIT:
Looking for 2000 lbs capacity min.
8" height when closed, min 37" height when open
Approx table dimensions of 32" x 76" (not 100% sure on this yet)
Power Unit:
What do you think?
Cylinders
End of Stroke
EDIT:
