Hydraulic solenoid on a work machine
ratdoggy
Akron-Canton area OH
We have a RUNI recycling machine at my work. It has jaws that compress the material ias it come out. They only are working in one direction. If I swap the connectors (1 and 2). The jaws will work in the other direction. But only one way. I think there is an electrical issue but sparks aren’t my thing. How can I test the connector for juice?
TurnipTruck
Southcentral Alaska
Your troubleshooting proves the hydraulic valve and their coils are good. The problem is from the plug back to whatever energizes it: ice cube relay/contactor/plc output card/upstream position switch or permissive. It will be either 120Vac or 24Vdc.
larry_g
oregon
https://www.compactor-runi.com/
I'd suggest that you contact the manufacture above and get a schematic for the machine you have. We don't know if this a old ladder logic machine or micro-processor controlled, or just a three position switch for up-off-down. When you activate for motion, does that also start the pump motor?
Turnip is correct in saying the valve is good, now you just have to find what powers each cord and follow the signal back.
lg
no neat sig line
Mr. T
Central PA
Ladder logic is still used in many “micro-processor controlled” machines.
When the machine is controlled by individual relays, the wiring of the relays can be described by ladder logic. I think this is what you were going for, I would personally call that a “relay logic” machine.
Small bit to pick. Not trying to be a jerk.
