Hydronic Heat Boiler Electrical Supply
nkachur
Manitoba Canada
OK, quick question.
Was running the electrical for my boiler and circulating pump.
3 ga RW90 for the supply wires for the boiler (70 amps)
14 ga RW90 for the pump and pump control wiring (15 amp)
started running rigid PVC for the RW90 and I feel like I am maybe pushing my luck.
Is there a problem with rigid PVC conduit when installed in the proximity of the waterlines of a hydronic (in floor heat) system.
Highbeam
Mt Rainier foothills, WA
Sorry, no answer to your electrical question other than it seems folks use the metal clad flexible conduit from the box to the pump. I like your simple radiant layout. Any reason you used black iron instead of copper or even pex?
Here is the first piece I installed that prompted this question.
I don't understand your concern withe the conduit ?
It is odd to see galvanized (I can't believe it is black iron) mixed in with copper on such a short run.
You ABSOLUTELY need dielectric unions where the galvanized meets the copper ! Maybe those are dielectric unions, but the one is in the wrong place. If not you will get corrosion and quick !
