I am about 2 weeks away from pouring my concrete slab with in slab heat. I am looking for some advice with a few questions I have on hooking up my system.
Garage is approx 1000sqft. I will have 5 loops with the longest loop being 264'. I purchased an Everhot 6 outlet manifold. The 6th out let will be used for a Rittling unit heater to heat approx 700 sqft shop area. Tubing run for this heater will be approx 50'.
I was told to use a Grundfos UPS15-58FC pump. Will this be enough pump to do the job?
I will be using an 80 gallon hot water heater as a temporary heat source for this winter with plans to install a coal boiler next year. Some have told me this will work fine and others have said I am pushing it using the 80 gallong water heater. Any opinions?
From what I have read they say to place the manifold about 2 feet off the floor. Does it matter how high up from the floor it is mounted?
As far as the hot water heater goes I would like to place it in a utility room I have but not sure about how far away from the manifold it is will make a difference. If I place it in the utility room my piping would have to climb 7' up from the manifold to the rafters then run across 30' to the utility room and 5' down to the hot water tank. I can place it about 20' closer but would prefer to keep it in the utility room if it would not make a big difference.
One more question I have is where should I place my pump? Close to the manifold or close to the hot water tank?
I hope this all made sense and any information you have would be helpful. With winter fast approaching I want to get this garage heated so I can get the Harley inside and start the restoration of my 1960 Corvette.
Thanks in advance,
Dave
Thanks in advance,
Dave
