Hydronic Radiant Heat System Piping Size
like2wheel
On an as needed basis
I already have five loops of 1/2” pex in my floor (1400 sqft), and I have been accumulating pieces for my Navien NHB110 boiler plumbing. I have several 3/4” sweat isolation flanges for the pumps (auction win), but when looking for a purge tee, I see the smallest available is 1 inch by 3/4 inch. Does that mean the primary loop needs to be at least 1 inch? Secondary loop?
Any input is appreciated.
L
like2wheel
3/4 is available.
Are you looking for sweat copper, threaded as above, or something else?
Question is though, why are you necking you boilers output and return down from 1" to 3/4"?
I guess I didn’t realize I was. Last summer I bought a T-H3M-DV–N 100 Takagi. That has three-quarter inch water piping. Then this fall there was an auction for a brand new Navien, so I thought I’d be better to use that. Didn’t realize that uses 1”.
So I have some other brass that I had accumulated that is also three-quarter inch. I’m guessing I should abandon that and pipe it 1 inch? Does that mean the secondary should be 1 inch also?
Here is a picture of the type of purge valve I was looking for. I was planning to use it to plumb my closely spaced tee’s.
fitter30
Peace Valley,mo
275' loop x 32 btu's per ft 8800 btu's per loop
9' + 2' = 11' for head need to know how many loops for gpm and pump size
Recommend a micro bubbler for air removal. Glycol? Use only boiler / chilled water type. Minimum 30% ( for the inhibitor package) can set up for two different protection. For hard freeze or slush. Slush will not freeze hard and will not break piping. Wouldn't recommend a permanent fill line. With a permanent fill if there is a leak and it's not detected glycol gets diluted and with a power failure system freeze. A cheap drill motor pump can fill the system and add solution if needed. Low water cut off for protection.
L
like2wheel
5 loops, my manual recommends a taco 0015-MSF3-IFC or a Grundfos UPS15-58 for what looks like the primary loop.
I do have a taco 007, and also a 0010 (more auction booty), wondering if either of those is suitable for the secondary pump.
fitter30
Peace Valley,mo
Takagi or Navian boiler
Taco 0015 msf3 ifc medium speed secondary loop
Gurdfos ups15-58 primary
L
like2wheel
I have a 5 gallon bucket of Cryotec 100, my boiler manual says to not go over 35%, so 30% sounds good.
My boiler manual says it has a built in pressure sensing LWCO set at 6psi.
