Hypertherm Plasma Problem
bfr57
I have a Hypertherm 600 that I'm having problems with. I'll be cutting and all of sudden the arc gets real weak and stops cutting. Even on sheet metal it'll just leave a little "trench" in the metal. There's still an arc, just not strong. I've changed out consumables-twice- and it still is doing it. Sometimes it'll start in that condition, other times in the middle of cuts. What could cause that? Should I look at my air source? I have a desiccant drier on it, but I would think if that's bad, it wouldn't cause intermittence.
one9gt
San Francisco
Have you checked your ground? I've had similar issues with mine and turned out to be a bad connection between ground cable and clamp
bfr57
I have not, but I will tonight. Thanks.
MoonRise
Hypertherm
Main 800-643-0030
Customer Service 800-737-2978
Technical Service 800-643-9878
