I am not an electrician
cowboybob56
Tucson, AZ
I just finished the walk thru on a new 2 car garage with an attached 4 BR house. I have the proverbial GFCI single outlet at the front of the garage and one normal which the opener plugs into. I can survive on extension cords for a while, but..........dang!!:shocking:Any recommendations on how to proceed to powering a full workbench, bike table lift with a 240V Compressor? Beyond the obvious?
DSLTRK
PHELAN, CA
With what I think you want to do, you might be better off having a licensed electrician look at your garage and different loads you want to run.:thumbup:
Sounds like a project for sure.
pattenp
Virginia - USA
The garage sounds like a canidate for a sub-panel if you have open space in the main panel. But that's the obvious.
matt151617
New Jersey
You'll need a subpanel, breakers, and lots of wire. Plan out what you'll want to have and the total amperage. This will determine how thick of wire needs to be run from the main panel to the subpanel.
Is it finished with drywall? If so you'll have much more work doing all that wiring.
C
cowboybob56
Tucson, AZ
It is finished dry wall, and I am not happy it is un-insulated. If I want it insulated then I must either pull the dry wall or blow in some. You are correct about the licensed electrician, I just have to find a legit one.
Thanks for the input
Aceman
Eastern Oregon
When you pick an electrician out, it wouldn't hurt to post up what his plan is for electrical and let us take a look at it. It seems the members on this forum have a knack for picking the shoddiest wannabe electricians....
Maybe we can save you a headache.
Steevo
43.49600, -112.04300
Where is the main electrical panel for this house?
Is it on one of the garage walls?
More info about the layout of the home and where the panel is and what the potential pathways are between there and the garage would be helpful in formulating recommendations.
frednoah
Mooresville NC
If your drywall is finished, you could do surface mount with EMT. Draw up your garage, and lay out where you want the outlets to be. I ran all of my EMT up high, then dropped down from 4x4 boxes to each outlet so I'd have plenty of room to make connections at the box. Make sure to pay attention to any corners that need to be turned, so that you can buy the proper fittings. You'll also need the fittings to connect the tubing to each box.
I was faced with a similar setup and it has worked for me. I got all the tubing up where I wanted it, then got some 12 gauge stranded wire and got it pulled to where all the outlets were going to be. Once all the wire was pulled I called my father (in your case the electrician) to come over and do the connections, including installing the breakers and hooking to the panel.
On your compressor, look up the manufacturers specs to figure out the amp draw. Once you know that you can look up what size wire you need. Pull it through your EMT to where the compressor is going to be, and have your electrician finish it from there.
The more of the grunt work you do as far as pulling wire and hanging EMT, the cheaper your bill from the electrician should be. And as long as he's doing the connections, I can't see it being a problem.
In my case, the main panel is located just inside the garage. If this isn't the case for you, this plan wouldn't really work.
C
cowboybob56
Tucson, AZ
I have a drawing of the garage but don't understand the upload. The 200 amp service Breaker Panel is near the front of the garage door on the outside wall.
