I built a laundry hamper holder.
nikerret
Kansas
Are you still laughing? This is my biggest welding project. I took a class, two years ago, which I detailed here: https://www.garagejournal.com/forum/showthread.php?t=319283
Since then, I have only used my welder a few times and only on tiny "fix it" projects. A few months ago, the Old Lady's laundry hamper shot craps. I decided it would be fun to build a new one. The old one was a frame on casters that held three bags.
This project ended up costing a lot more than I had hoped, but it should last forever...Around $35 in steel, $5 in bolts/lock nuts, $30 in casters, and some money in wire wheels/grinders/flap discs.
The following tools were used:
Welder: Forney 130FI (Yes, it's the same as a Clarke, Craftsman, HTP) 120v w/.035 Forney brand Flux-Cored wire.
Welpers: Channellock
Angle Grinder DeWalt DWE402 11 Amp, 11K RPM
Welding Helmet: Metal Man from Tractor Supply Company (still on two year old battery.
Welding Gloves: Lincoln Electric Red ones.
Drill: DeWalt DCD996 Brushless XR w/6.0 Ah battery.
Steel:
14" of 2"x1/4" flat=1
24" of 1/2" round=2
18" of 1"x1/8" angle=4
24" of 1"x1/8" angle=4
28" of 1"x1/8" angle=4
I only had the angle grinder or an air grinder to cut the 14" long, 2" wide, 1/4" flat stock into 3.5" coupons. Due to my lack of skill, they all came out crooked. To try to fix this, I squared up one side and clamped them to my welding table. Yes, that tiny workspace is my welding table. I then used a flap disc to try to make the cut sides all the same. I turned the pieces around and repeated. This was close enough.
About the welding table, it was a hand-me-down from a friend who ran a fab shop. He had it on a small crane. The hole and cutout make it nice to use clamps with, but it's a very small space, for what I was doing.
I then used the wire brushes on the 28" angle to weld the 24" to it.
I made sure it was square and clamped it. I'm not good enough to notch the angle, like a pro, so I did this hack job:
Here's the first weld, right after I did it, before any de-slagging. Not as bad as I expected, since it had been so long, since the last time I welded anything. Yeah, I know, it's ugly. However, it is pretty strong. I gave it the muscle a few different directions, to test.
I continued making the frame, for one side:
Somewhere during the second frame, I realized I switched which piece when where. The 28" angle was supposed to be the runner and the 24" was to be the height posts. I cussed and continued onward, hoping for the best. Of course, I had welded every joint I could.
Here's the welder and the setting I used. Since it's a 120v, I left it plugged in. I have found that it will trip the breaker, if I just plug it in and go. This way, it stays full of juice and the fan keeps blowing. My electrical setup is crappy. The plugin I use for the welder is plugged into another plugin that goes to another box with plugins and then to the breaker box. When I put my sub-panel in, I will have dedicated 120v and 240v lines.
I did have issues with the wire, at one point. I was using a two pound spool and somehow, it got very locked up. I took it out and by the time I got the wire to come off the spool like it should, instead of from the bottom, I had removed a lot of wire. Around 20+ feet of it, I would guess.
Again, due to my lack of proper tools, I had to improvise. To get the holes right, for the casters in the 1/4" flat, I clamped them down and drilled two holes, through the caster plate. I then put the bolts in and clamped it down, with the bolts keeping the back holes lined up. I used my DeWalt 886 and a cobalt 1/4" drill bit, since I don't have a drill press.
Here, you can see the 1/2" round stock I used and rails, for the hangers. I paid hell trying to weld that in. I think the solid round and the thinner flat, combined with my weak welder and poor welding ability all played a part. You can also see the 1/4" flat I welded to the bases of the legs, to mount the casters.
Here's one of the casters. It is the "non-marking" swivel kind.
Here's the functional product, in it's new habitat:
And the final rough (pre-paint) product with the hamper bags:
Another picture, of the bottom sections. I am going to put a rubber hose around the 1/4" flat, the casters are bolted to, after I paint it. The rounding of the corners was done with the angle grinder and a flap disc.
To my great surprise, the damn thing is even close enough to square it doesn't wobble, at all.
Stooge
South Shore, MA
Hey that's pretty cool! should be nice and handy and its always fun to get out there and build something. Thanks for taking the time to share it, and I liked reading the details of it
bad_idea
Pasquotank, NC
Looks good. Smart making the first major project one for the wife. It justifies the tools to her. I have done my best to do the same through the years. I have built her an end table, mail box post (artsy metal thing), curtain rods, and misc items through the years. She loves them, as I'm sure your wife will.
Can I make one suggestion? Rather than center the casters under the leg, shift the plate for the wheel to the edge of the leg. That way the outside of the leg stays smooth. Should be able to slice the plate off and only lose 1/8" of height.
StormcrowAz
Phoenix, AZ
Looks good to me. Not much to laugh at, it’s a lot nicer than what I’m dumping my laundry into.
If you’re not feeling froggy enough to make those nice 45 degree cuts - this is something I found and have tried with success:
notch
angle notch
Minimal effort with a cutting wheel on your grinder. The 90 degree cuts are easier to manage/calculate if doing it by hand and you end up with pretty close to the same results as the “pro” notch job. Also - If you’re making an angle iron frame and want to put something “inside” the angle, it also allows whatever it is to sit flush all the way around. Just weld the outside corners only as it’s hard to hand-finish the inside of the corners. Nice thing I’ve found with MIG, it is pretty forgiving for filling any small gaps you end up with.
N
nikerret
Kansas
No wife, live-in girlfriend (and baby momma). Our finances are completely separate, but it is always better to have her happier.
I didn't even think of that. I was too worried about getting the nuts on the bolts and centered it where that would be easiest.
N
nikerret
Kansas
Thank you all for the compliments. It was fun and overall a positive experience. No one can make something and not feel a sense of pride and accomplishment.
I will keep the tips in mind and post another picture, after it's painted.
Wanna Ride
Looks good! Once you build a couple things, you see all kinds of other projects to make things more convenient. Only things I'd criticize is the corner joints (someone above also mentioned) and the caster placement. Whenever I build anything with casters, I always try to set them in, so they don't interfere with the ability to push the cart up against a wall, into a corner, and so they don't increase the overall, outer dimensions of the cart.
I use casters on almost everything I've built in my shop; the welding table, the drill press, the sheetmetal brake, the 20-ton press, the air compressor, etc. Makes it very easy to move the tool where you need it and makes it much easier to keep the floor clean, when sweeping up.
