I can be kinda forgetful, so.....
coljar
Belpre, Ohio
I put a running light for the compressor by the front man door of the garage so I know the breaker is switched on and I'll see it as I leave. Yes, I know you're not suppose to use a breaker as a switch, but the compressor next door in the old garage has had the same set up since before I was born and I'm 60.
jayrush13
Lebanon Oregon
In my Dads shop growing up he put a contactor wired in to the main shop lights so if you turned the lights off the compressor was turned off.
Fyrme
Green country, Oklahoma
Actually, you can use a breaker as a switch.
"......Both the ANSI and the NEC definitions acknowledge the potential for the legitimate use of circuit breakers as switches. Switches (pass, but do not consume electrical power) are considered as being control devices, thus one may also say that a breaker is a control device, or a controller.
To aid in the understanding of a fine point, I offer this comparative example. A gas valve and a steam pressure relief valve are both controllers, one the fuel to the burners that aids in the development steam pressure, and the pressure relief valve that opens on excessive pressure. Both are controllers, one operating (the gas valve) the other safety (the relief valve).
Likewise in a parallel manner; we say that a circuit breaker can control and protect an electrical circuit. An electrical relay is an example of an operating control; it opens and closes the circuit. Circuit breakers are not designed as replacements for relays, operating controls.
There is as you may intuitively have anticipated an exception. Some circuit breakers are manufactured for use in a specific type of application. When a circuit breaker is designed to also be routinely used as an on-off switch to control 277 volt florescent luminaires they are marked SWD, for switch duty. This does not mean that a switch duty breaker can be used to manually control a traffic signal light where it will be cycled 1,000 or more times per day. The point is; the listing for switch duty (SWD) does not mean a circuit breaker can be used as a high frequency cycling operating control, such as a relay that has a life span rated in tens, if not hundreds of thousands of duty cycles.
While circuit breakers can be legitimately and safely used as switches, the frequency and duration of such use is very limited. Routinely circuit breakers are manually operated for service-maintenance, and repair type activities. With the preceding enhancing our understanding; we can say that circuit breakers can legitimately be used as switches, generally they are not intended for prolonged frequent or repetitive manual breaking and making type control of electrical energy utilization equipment. ......."
I haven't done it yet, but I plan to not only have a light by the door, but also a set of illuminated momentary contact buttons by the door, green for on, red for off, that are wired to the starter on my compressor. I know it's way overkill, but a buddy of mine has this in his shop flush mounted, and being a commercial electrician for 24 years, its too cool not to, right!?
NUTTSGT
Northern Central Ohio
I generally leave the compressor on but shut off the air supply to the lines. Apparently, I forgot to close the valve as I heard the compressor kick on while I had the dog out this morning.
I like the idea of having a light to be reminded of a compressor being on.
YukonXL04
Arlington, TX
Sounds like a owner that doesn't maintain air leaks. My compressor stays one 24/7 and it only cycles when I use it.
This... granted mine is only a 20 gallon with nothing hooked to it. But that way it's full whenever I need it and don't have to wait for it to fill.
When I left it was at 125 psi, come back 2 months later it's still at 125, though this time it was turned off. No leaks.
Fyrme
Great idea. Maybe someday all of us will be as perfect as a few here. Until then I like the OP's idea.
I claim zero perfection in my life. If you read the post before, I did mention I have plans of doing something similar, so obviously I agree that it's a good idea. A hissing air line to me is like fingernails on a chalkboard. I will drop whatever i"m doing to go fix a air leak. I realize that an air leak doesn't bother everyone, but hell, if you read half the post on GJ, proper equipment maintenance is some kind of prerequisite to be a member here from what I've read.
FTG-05
TN
I did the same thing. I originally had just the 240 vac 60 amp switch but then read a thread here about adding a light and the consensus was that to do it right, you really needed a 120 vac CB, so I added a $22 CB box, then wired a 120 vac outlet.
You see the switch far right, then the CB box just to it's left. The light is on, but you can't see it just above the pic.
Another.......... EXACTLY!
The line that feeds my pressure switch ruptured just the other day and so the switch was engaged, compressor running, and my safety valve bleeding off the more than 30 pounds over. I switch mine off now when not in use. My compressor is a 6.5 HP 65 gallon in the basement.
YukonXL04
Arlington, TX
Lol this! I can't stand air leaks! Drives me crazy. Not perfect here either, but that's just one of those peeves of mine.
jmarkwolf
Southeast Michigan
I like this idea also.
I'm installing a power draw bar on my milling machine which will will need the air compressor. Don't want to leave it on all the time though.
Can you or anyone the forum provide more detail on how/where to do this?
GarageGuy89
Olalla, WA
I need one of these lights! I have a small leak that can't be heard at the pressure switch. It will cycle the compressor 2 or 3 times a day if I leave it on.
Because the leak is so small, I haven't found the time to fix it....
laser3kw
northen IL
I installed one of these on my compressor.
240 volt rated, double poled, breaks both sides of 240v single phase, motor rated
240 v switch link
there are 3 phase version also
if you wanted a pilot light, you could insall this in a double box with the piloy light on the other side. You would have to run a neutral with you 240v feeds to operate a 120v pilot - or find a 240 volt pilot lamp
C
coljar
Belpre, Ohio
The funny thing about this Allen Bradley box and pilot light is, it's something I dug out of the dumpster at work and got a scrap pass for 20+ years ago and finally found a use for it.
nadogail
Coronado, CA
Definitely not a bad idea, reminders are pretty nice to have around; it is when they start nagging i consider replacing them.
240 v switch link
what is the HP rating on your compressor motor?
That switch is rated max 2HP...
so hopefully your compressor is 2HP or less...
https://www.leviton.com/en/products/3032-2
exranger06
CT
I'm installing a toggle switch in the garage to control the starter on the compressor. The toggle switch has a pilot light built in.
C
coljar
Belpre, Ohio
I have one of these on the timed blowoff tank solenoid and I have one on the "point of use" water heater for the shop sink.
Dragfluid
Pillager, MN
My tinnitus doesn't allow me to hear the air leak that I know that I have. I need to have one of the youngsters walk around the line and find it one of these days.
In the mean time, I close the ball valve and shut off the knife switch when not in use.
Very good idea, OP.
