I did the impeller mod to my snowblower
fury9
Mchenry, IlLaHnoYs
I don't do many write-ups so..I got the snowblower for free from my cousin. MTD 5hp 22" path. I did this on the cheap and on the fly as my son was napping (don't worry I have a baby monitor in the garage with me).
I tossed the ol Toro s-200 out on a snowbank for the scrappers once I got the new one up and running. Then I came across the snowblower mod thread. I ran out to the curb and snatched the old one back so I could use the flapper paddles for my mod. They are corded rubber.
I kind of hacked it together real quick. I will keep an eye on those self tapping screws that are holding the rubber to the impeller, although I don't see this thing producing a lot of rpm. They came off the toro paddles.
Don't mind the mess in the garage I was drinkin out there last night and have yet to clean it up. I got lucky and had ample room to work through the chute once I took it off.
I can't try it yet as I was cleaning the carb again I accidentally blew some little piece to who knows where, it was for the float needle to seat in the carb body. New carb ordered.
Pics.
The first couple pics are of the gap between the impeller blades and the body. This gap causes the snow to build up and clog the chute. Probably 1/2" or so gap. This should be able to clear a puddle of slush now. Will update.
F
fury9
Mchenry, IlLaHnoYs
The Clarence website says you only need to do the flat spot. Keep in mind that if you bolt the chute back on there will be bolt heads protruding through and the paddles will hit them. I just gave it about 10 good pulls and everything seems to have seated itself good enough till I can put the new carb on.
F
fury9
Mchenry, IlLaHnoYs
New carb is on and I'm just waiting for some snow, Thing runs like a top! I'm amazed at what some people consider junk. Oh, it's Made In USA too.
polexican23
burbs-Illinois
yeah had i thought better of it, I would have kept my grandparent Arien's they had. They said the motor was no good. Can buy a new motor at HF for $95 with more hp. Oh well you live and learn.
btw, good find and good mod.
roche
I've been debating doing this on my old Toro. I have a 3/8" gap. :dunno:
