I doubt its enough.
mrg7243
I have a 4 car detached garage that has finally been cleared out so it can be used for what it is intended for, a garage. Over the past week I have been going through all of my spare parts and trying to setup my benches. But the thought keeps coming back to me before I start working on auto projects is: Do I have enough power?
The garage has a sub-panel breaker box with 2 breakers at 20amps each, one for the lights and one for the 1 outlet(yes 1 outlet in the entire garage). Now I am adding outlets and that is not the worry, the worry is the breaker in the house. The breaker inside the house is a single 30amp breaker for the whole garage. Now I was doing some adding up and well I think I will be pushing the breaker limits.
Say I am in the garage at night with my welder pulling 20 amps(pushing the single breaker??), with the lights on pulling 4.1 amps 100watts x 5/120, and someone walks by setting off the motion lights/outside bay lights which would pull and additional 110 watts*6/120 5.5 amps. My grand total of amps in the garage would be 29.6 at a minimum if I dont have the radio or another drop light going. I think that is pushing the limits of a 45 year old breaker and the roughly 200 feet of wire between the garage and the breaker in the house.
I do plan on pulling the panel off in the garage and inside the house to measure the wire to see if I can put in a bigger breaker on the house side and add another breaker on the garage side. But is what I have enough? or am I just not thinking about this right?
pattenp
Virginia - USA
Yeah, 30A is a little lean. Plus at 200ft you are probably suffering some voltage drop. It sounds like you may need an upgrade.
Charles (in GA)
50 mi south of Atlanta
Looks like its time to start making plans for a new power feed to the shop. At minimum, a 2-2-2-4 MHF with a 90 amp supply breaker in the main panel and a decent sized (20 or more spaces) panel in the shop with a main breaker in it.
Charles
sands35
St. Joseph, MI
Charles
That needs to be made a sticky.
mrg7243
Ya'll are wonderfull. I am hoping there is wire supporting bigger amperage behind the 30amp breaker in the house. This will allow me to get away will the little stuff here until I move out.
