somebody slipped in a bid under you.........fun huh!
Yeah I think so. I clicked on "Place bid" at 5 minutes to go and just stayed ready at the "confirm bid" button until 6:59:45PM came around and then I clicked the button. I guess in those last 5 minutes when I wasn't watching the current bid, someone snuck a bid in underneath me like you said.![]()
Once again Merkva,not trying to push you, but if you want mine, PM me, its a 936 version of that.
Merk just go up to your toolbar click file then click new window it will open up a new window of the same page you are looking at then you can refresh that window while holding the other to place your bid.
Rick
Okay. Pull up the auction you want to bid on. Copy the URL out of the bar at the top of the page, and open a new window. Paste it in the bar there, and hit enter. Now you have the same webpage up twice. Use one to place your bid at the last second, and the other to keep refreshing the auction to see if anyone bids.
Thank you for the sympathy; I need it.
Why !?!
that's why I always have a second window of the auction open and keep refreshing it until the end.
I need a 16mm anyway.![]()
I still have my dedicated OEXM160 vintage at the ready though.![]()
Sometimes when I buy **** at HF that needs to be assembled, I have to use a 16mm wrench... and a 15mm and a 17mm, because none of the bolt heads are consistent!
They definitely use some crazy fasteners on that stuff. 1/4-20 thread with a 10mm head, or 5/8" nuts on 8mm fasteners.
I have seen some that NOTHING would fit except an adjustable wrench.
When I was putting together a welding cart, I found a supposedly 8 or 10mm bolt with - 5 side. Maybe Chinese numbers skip 6????
