A little explanation might be in order vs. just slamming the work as amateur. Help us understand a better way for next time.Typical DIY job when you see the use of handy boxes. There is almost never a good reason to use them.
Maybe he used scotchlocks!they're too small. The common shallow size is so small it's over filled if it's anything but a a dead end with a device on it. Even 6 14 awg wires and two wire nuts (what's probably in these) is overfilled. there are deeper ones (and I can't tell what's been used here), but they're still small for lots of uses. The smallest readily available 4" square boxes are much bigger, easier to work with, but they cost 50 cents more...
Too small to be useful for anything. Nothing wrong with junctions but use a 4x4 box instead.A little explanation might be in order vs. just slamming the work as amateur. Help us understand a better way for next time.
You're correct, it is DIY. The reason for the handy boxes is because in my trade, we dispose of gondolas filled with extra material. I happen to have a **** ton of certain stuff, and decided to use it. Yes, they are the deep version.Typical DIY job when you see the use of handy boxes. There is almost never a good reason to use them.
These were recommended by a friend that read satisfactory reviews. After hanging the first, I was really nervous. I didn't think they would be bright enough. I originally wanted to do two per beam. But then I ordered 8' lights, and then decided to use the 8' on the sides. I had so many 4', I decided to put 3 per beam, and I like it. They were inexpensive, but this is a kind of temporary shop until my 50x100 is built.One of the reasons I like the old fluorescent fixtures with 'tombstones'. The fixture itself is the wiring trough. Update to LED tubes as you see fit.
No lamp wire. I used the wires with plugs, that were included with the lights. Those were Wago lever nutted to the THHN stranded ran throughout.I'm more concerned that it looks like lamp wire may be cut and joined inside the box then the fact that the boxes were used.
Everyone is an expert on the internet! Heck, I'm youtube a certified, car mechanic, heavy equipment mechanic, weldor, electrician, carpenter, chef, political analyst, and many more.A little explanation might be in order vs. just slamming the work as amateur. Help us understand a better way for next time.
As a peace offering and showing no hard feelings, ship all extra handy boxes to NorCal.
I scrap them. 99 9/10ths of the time they are the worst choice.As a peace offering and showing no hard feelings, ship all extra handy boxes to NorCal.
I like them for extension cordsI scrap them. 99 9/10ths of the time they are the worst choice.
No.So you cut the factory plug off, passed the wire into the handy box somehow (grommet? Clamp?) and used a wago to splice to the thhn?
In typical GJ thinking, it might be nice to have some on hand for that 1/10 of the time you might need them.I scrap them. 99 9/10ths of the time they are the worst choice.
