georgelowcar
hello,
i have an detached uninsulated garage (30x30 ft). The garage doors are also metal, uninsulated facing the north. The summers have been oh so brutal. When its hot outside, its unbearable inside the garage. I have had soles of stored shoes melt. Forget about working in the garage.
I'm not asking to cool it to 80 degrees, but i'm hoping i can at least cool it to at least the outside temperate in the shade.
Current solution:
Currently, all i have is a ridge vent and the two opposed windows.
Solution 1:
I'm thinking about putting in one exhaust fan with a vent opening on one end of the garage 'A' frame, and another vent opening on the opposite side. I would then draw air in and exhaust the air.
Solution 2:
Currently, I have two oposed windows. Another option is to put a descent fan on one of these windows and leave the other open to draw air out. Basically, same solution as solution 1, but use existing windows which are already there, but 10ft lower.
Solution 3:
Ceiling fan to draw the air down and then use a fan on the windows to push it out.
I could also leave the garage doors open, but then worry about unwelcome critters.
Do you think creating vents on opposed sides and adding a vent is worth it?. Any idea what type of fan should be used.
thank you
- george
Current solution:
Solution 1:
Solution 2:
Solution 3:
thank you
- george
