I just found an amprobe hd 110 multimeter
jeff lary
Hartland Maine
Hi I was just walking my dog and in the ditch I found an Amprobe hd 110 multimeter. Now I have a harbor freight freebie but this is a fraction better I think. Anyway now my question is there a booklet or book that explains how to use it? I have taken notes when I needed to test a 12v battery and used my HF to do it and it worked fine. My need would be stuff like this maybe checking for a broken wire in an ATV or an on / off switch on a chainsaw. I am an electrical idiot I know less than zero about using a multimeter but I would like to know how to if I should need to. Is there a booklet for this sort of thing designed with dummies in mind?
J
jeff lary
Hartland Maine
sorry yes this is the 110 C and thanks I think I saw that online and I will look again. I think the manual though assumes that you already know how to use one and are very familiar with the nomenclature used to describe how to use the rig.
Worsedog
Central FL
That's quite a bit more than a fraction above a horrible freight meter. Lucky sod if it still works.
