ForceFed70
But will it be safe?
I ran 10/3 wire with a 30A single pole breaker to my RV plug.
The plan for now is to have a single phase 30A RV plug and not use one of the conductors.
However, I ran 3 conductors and used a 2-gange box so if at some point I want to upgrade to a 50A style plug I can. At that time, I would still use a 30A (10ga wire) breaker but would switch to a 2-pole breaker and use the spare conductor.
I know code says you can't do this. A 50A plug must have a 50A breaker and suitably sized conductors.
But, I really don't see using a 50A plug anytime soon if ever, and if I do I'm thinking I could squeek by with only 30A.
So long as I'm not tripping the breaker, this should be a safe setup should it not? If it turns out that I do need to use the 50A style plug often, I will upgrade at that time. I'm more thinking along the lines of friends/family showing up with a big RV or something which wouldn't happen very often.
