I know "whatzit," but Howzit?
Twertsy, Penen's was more of a contractor/re-seller to the US Gov than a manufacturer, so not surprisingly that would appear to be a Fleet ratchet just posted in another Ratchet thread:
I've heard they DID had some small bit of Mfg capacity, but it was likely bought from some other company. Most of the Pennins stuff I see is from the vast Plvmb/Proto family of manufacturers
T
twertsy
Reedville, VA
Penens operated under Plomb out of the Bog Manufacturing plant in Chicago from about '43 on. In '63, Pendleton changed the Penens name to Fleet.
The info I have (which with this era/companies is admittedly sketchy at best), indicates Penen's started in the mid 30's, possibly earlier, and Bog started in 23, and was acquired by Plvmb in 39/40. I don't have anything showing Penens acquired Bog or vise versa, but Penens was acquired by Plvmb in 42/43 time frame. Penens/Plvmb used the Fleet TM starting about '43, and about '51 they added Challenger. and yes Penens name became Fleet in 63/4
So far Ive been able to track the following early Co's into Proto: Vlchek, J.P Danielson, Penens, Bog, P&C, and General Tool (arm of P&C). I'm sure there is more... :eyecrazy:
T
twertsy
Reedville, VA
Re: I know "whatzit," but Howzit?
Penens was created out of thin air by Plomb, replacing Fleet as their contract management arm during WW2.
Look under Timelines and case studies on my site, then the Plomb timeline. I posted a court transcript explaining it.
Sent from my SM-P905V using Tapatalk
