Well I have had this floor heat running Since mid Dec....... I had a few initial concerns about my system as the slab was not insulated......Some guys told me my boiler would struggle to keep up even........ However I am happy to say the heat works awesome ! I keep the thermostat at 64 and it seems during the day the shop sits at 68-70 and the boiler doesn't even come on till night..............The system seem to be very powerful and fast...if the shop is at 64 I can adjust the stat to 67 and it only takes about 20 minutes to come up 3 degrees, and this is in a -20 C climate............. My shop does have closed cel foam insulation from top to bottom, so that must help...But I must say this floor system is much better then I was expecting.... I am using a 8KW Lion Boiler....shop is 22x28 with 10"ceiling and 2lb closed cell foam in walls and rafters...slab however has zero insulation
