bluedog225
Good afternoon,Trying to deal with wood beetles. Need to get it behind me so I can get on with finish out. I sprayed 4 gallons of Timbor on my shop today. 8 gallons at the one-to-one mix ratio.
I started with a little Ryobi 18 V sprayer. While a lot of times those little cheap Ryobi tools punch above their weight, this was not one of them. It was misery.
After a gallon I switched to a Home Depot 2 gallon pump sprayer. It was many times better. But still a pain in the ***.
I finished the jobbwith the hand pump sprayer. Going forward I’ll need to spray some more timbor. Maybe 8 more gallons. I’ll also use the sprayer for general spray stuff. No finish work.
I’ve got a small compressor. Would somebody recommend a set up for what I’m doing. The Timbor unmixed is a little bit thick, like paint, but pretty watery once you mix it in with a gallon of water.
I don’t mind something cheap from Harbor freight. I can think of maybe a half dozen jobs for the sprayer before I’m done with it, it would be good if they could hold at least a couple of gallons.
Also, it does need some reach to get the high walls.
Any recs appreciated.
Thanks
