I need a flat countersinkIng gizmo
nissan_crawler
Wichita, KS
Ok, I'm making new motor mounts for my bicycle. They're going to be a clamshell mount out of aluminum. I'm going to use socket head cap screws and want them to be countersunk into the mount. Whats the name of a cutter I can use in a drill press to make a flat countersink?
merr6267
Ravenna, MI
That is commonsly called a "counterbore" where a countersink would be a tapered hole for a flat head screw.
Google counterbore, then look in the "shopping" tab. There are a few for sale that way. Of course there are countless others on many industrial sites. McMaster, etc.
Have fun.
Phill
Neohio
Painesville, Ohio
What about using an End mill? Should be flat bottom. Just drill to the depth you want with a reg bit, then flatten the bottom with an end mill.
OccupantRJ
Eastern North Carolina
The counterbores can also be created by drilling with a proper sized drill, then flattening the bottom of the counterbores with a drill sharpened to have a flat end. This is why it is important to be able to grind one's own cutting tools. It allows much more freedom in creating things as needed.
A_Pmech
IL
Beat me to it!
A flat ground drill is an easy and fast way to c-bore. :thumbup:
Graham08
Iron Station, NC
I've got a set of counterbore cutters. The only thing to be careful of is the pilot is usually 1/32" oversize on them...meaning you need to drill a 9/32" hole for a 1/4" screw. Okay for tension applications, but not so good when you're cheating and using the bolt for location + attachment.
N
nissan_crawler
Wichita, KS
Thanks guys. I went to the yard and ended up with a 1/2" end mill, 5/8" end mill, 1" reamer, tap handle, and 2-1/4" socket for $26.
The end mill worked great, and the price was right at $5 per pound.
metal4130
Beat me to it!
A couple of tool and die veterans showed me this trick too. Doing it this way allows you to make a c-bore for any size hole.
The trick is learning how to grind the dill bit flat so each flute is symmetrical. If not, one flue will start to cut before the other and then the drill can start to walk on you as you drill.
When your done, if you have an end mill of the same size you can use it to make the bottom of the c-bore nice and square.
