I need a grease gun
bad_idea
Pasquotank, NC
I am a home enthusiast with a few older vehicles to lube up. I bought a HF cheapie and it didn't last too long. It gave me plenty of grief along the way. I want to buy a nice one now. I have Dewalt 20v tools, so I am thinking about the DCGG571B. I also see LocknLube is another good choice. Not sure my uses justify the cordless one, shouldn't need to pump large volumes into any one fitting. What says the journal?
finn
The UP, God's country
I have three pieces of equipment plus a dump truck that need regular greasing, and it’s a task I despise, so I bought the 20v Dewalt.
I still hate greasing, but it’s a little more tolerable now, and not as messy. Probably not worth the money for occasional use though. Lock & Lube is a recognized brand. I probably got both of my manual guns at Farm and Fleet or maybe one I from my dad fron the sixties. One is an Alemite brand.
ihateminimumwage
Go with the Dewalt, you won't regret it. In my experience, you'll no longer absolutely dread having to grease stuff. Lock and Lube is an awesome addition (the real one, the knock offs don't last).
Sumboodie
AK
If you buy on the locker lube website, they sell the Dewilt and milfaukee guns for the best price I've found.
matthew
Farm machinery uses a lot of grease. If you’re in an area with farming, a farm supply store or farm dealer is a good source. John Deere has some good ones. At least years ago they had a few models, and the black ones were better than the green ones. Napa guns also held up well.
Cordless is great, but I don’t think it’s worth it for very occasional use.
Sumboodie
AK
For a car, hand pump wouldn't be bad.
On equipment I'd be in a world of hurt without cordless or air powered.
Often use 1-2 tubes when greasing 1 thing, lot of pumps!
G-ManBart
I read all sorts of reviews and the Lincoln grease guns were highly recommended. Either things have changed or I got a total dud, but it's awful. If it sits for any length of time it will leak nearly an entire tube...so bad I kept it in an oil drain pan. I found it would also lose prime in the middle of using it, which is annoying because that's when I'm wearing nitrile gloves, have greasy rags, etc and trying to sort out the gun gets messy.
I finally had enough and bought the Lock N Lube which is a huge improvement. It will leak a drip of grease here and there, but nothing offensive. It also haven't had it lose prime once it's loaded and pumping grease. I still may get a Dewalt cordless since I've got a few things that use a fair amount of grease, but I'm not in as much of a rush after selling my dozer and backhoe.
ecotec
I keep mine in plastic bins.
I have had a lot of bad experiences with leaky grease guns.
My method, at this point, is to buy up any barely used looking made in USA grease gun and get rid of the problematic ones.
matthew
I spent a lot of time on my grandfathers farm. It’s been a lot of years ago. We had cordless, but they weren’t nearly as good years ago, perpetually had no batteries, and they stayed in the shop. I started a lot of mornings pumping a couple of tubes of grease into the disc and into the tractor articulation joints by hand. I actually didn’t mind, i was young and I took pride in being a good operator. And needed something to do while fuelling. But cordless is definitely nicer.
dchawk81
M18 grease gun was one of the best purchases I've ever made. Get more use out of it than the 2767 it came with in a kit.
SCWOOD
LockNLube Easy-Prime Lever Grease. I bought this one. I have used 3/4 tube of grease.I know this because all I have to do is look in tube. So far I like it.​
DrinkMan
Georgia, USA
I use the DeWalt. Makes the job very easy. Quick, easy, and not messy. A friend saw me use it and laughed at me and said it was too indulgent. I let him borrow it. He changed his mind and bought one too.
Sumboodie
AK
My wrists sbother me if I do.alot of repeating grabbing/gripping.
Like stacking firewood I have to wrap my wrists in compression tape usually.
Was supposed to get carpal tunnel surgery but then they weren't willing to accommodate my schedule and wanted "no work" for 2+ months so not happening.
2 weeks... mayyyybee I could do.
Drs so disconnected with us poors they couldn't grasp that a person can't just take months of work off.
$$ wise yeah I "could" do it, but I'd certainly not want to dig into emergency $$ for that.
Plus who's doing my work when I'm not? The Doctors? Haha
Sportsman762
OH
I like manual grease guns for occasional greasing. Power Greasers are great for situations where you have lots of grease fittings. If your greasing a backhoe, dozer, or heavy equipment every day a power greaser is the way to go. Otherwise it is a lot of money for a low use item. When I worked for a driller and go through 2 tubes of grease when I would grease the rig, a power greaser would have been nice. I hate locking grease couplers. On stuck fittings, they make a damn mess when you have to bleed pressure off to get them to release. A 4 jaw coupler will pop loose with excess pressure and you lose only a little bit of grease. Due to the odd places engineers like to put grease fittings I like a long hose on a grease gun. Locking couplers are a SOB with hard to reach fittings as they are hard to reach to disconnect. A hose and a 4 jaw coupler allows me to get into most odd spots easier and a little wiggle and tug and they come free. Never had an issue with the hose being too long, just too short.
My preference is for pump style manual grease guns. It allows for more pressure, and pistol grip style causes my hand to hurt.
Alemite 555E, Lincoln 1133 pistol style, 1142 or 1147 pump style are all excellent grease guns. I change the end out for the Lincoln G300 4 jaw coupler as it makes them grab the zerk better, the 3 jaw couplers that come with them ****.
Here are a few tricks I have learned about grease guns. To check the amount of grease left, just pull the T handle in the bottom out. If it only comes out a little then your almost out, if it comes out a lot, then your pretty full. When loading new tubes, just screw the head on two or three turns then use the T handle and rotate it until it engages the follower then tap it on something a few times, give the gun a few pumps to clear any air and then screw the head on tight. 95% of the time you will have no problem with air lock.
bad_idea
Pasquotank, NC
I picked up the LocknLube LNL151 with the extended nozzle. Thanks all. $80 for a grease gun seemed nuts, but just couldn't justify the $150 for the Dewalt. I've had a few **** cheapies through the years, hope this one does a lot better.
Pexto
I needed a new grease gun for the special cold-weather grease for my snowmachine. First I went to my local autoparts store and looked at the grease guns. The $50 Lincoln looked to be very low quality so I shrugged my shoulders and went for the $30 Performance. When I got home I realized the box said 'lifetime warranty' but the paperwork inside said '90 days'. Which pissed me off a bit. And the more I looked at it, the more it looked to be of low quality. So I took it back.
Then I searched GJ (yeah, I should've done that in the 1st place) and based on old threads I went with an Alemite 555E. This is a quality unit; it is well-made and well finished. And it will shoot grease clear across the room! Time will tell if it will be durable, but so far I'm quite happy with it.
boom_bap
Idaho
Alemite 555E used to be miUSA as with the Lincolns. I think today, its a matter of which ever is cheaper. Both made overseas for future readers.
mogandave
Bangkok
Another fan of Alemite.
If you have a kid, put a long hose on it and let them pump. Then, when they're 10 or 12, you can stay out from under the car and pump...
mikegt4
sw ohio
I have a Macnaught manual grease gun, it's built like a tank and makes the typical Asian grease gun look like a toy. They are currently on sale at a really good prices, available in pistol grip or lever.
Dave455
Sussex, England
Best I’ve ever used, by far, are the Wanner. Made in Switzerland, and superb quality.
I don’t think the design has changed much in decades. They’re still available new, but where I am in the U.K. they can usually be found on fleabay for reasonable money.
I have one of my Dad’s - got to be 50 years old, and another I inherited that’s even older. Both work fine.611FD186-8CF1-4841-B4AE-A5D3BA647D94.jpeg
WWheeler
Middleofnowhere USA
Had a Lincoln for 20 years or so and loved it, but early last year when it died and I found they were no longer made in USA I decided to give a Lock-n-Lube LNL153 Pistol Grip a try instead, and it's been great for our vehicles. FYI it's not made in USA either, but I had been interested in the locking coupler so price-wise it made the most sense to me at the time to get the one that comes with it on it, and I'm glad I did. It's been a game changer and fits everywhere I needed it to which was the one worry I had getting it. It seems really solid and I like that it has a dummy zerk for storing the coupler so dirt and **** don't get in it (also makes for a convenient way to carry or hang it by the hose). Going on a year now I've zero complaints and I'm hopeful it will give me decades of service like my Lincoln did. Only time will tell. If I do have any problems with it Lock-n-Lube seems to be a good company to deal with (or at least their marketing makes me believe so).
Then a few weeks later I picked up a Dewalt cordless for greasing our equipment which was a long time overdue. I put a Lock-n-Lube coupler on it too. It makes such quick work of what used to be a real chore and one that was too often neglected which cost us downtime & $$. It was a job that used to fall mostly on my brother or our boys, but now it's all mine. Can't even believe now we went so long without it.
Another vote for alemite 555 pistol grip. I’ve had one for 10 plus years always just tossed in back of truck after greasing equipment. Never had any problems getting it to prime just money well spent
Farmall450
Marengo, Illinois
I like my DeWalt cordless. You can't beat a cordless grease gun (I have a LNL on it). Where the LNL doesn't fit I have a pistol grip lincoln w/ the flexila hose.
signcrafter
Those that have the cordless guns, are you mostly using them on equipment or vehicles? I'm usually all for cordless but even with working on family and friends vehicles I don't run into a ton of grease fittings. I've been wanting to upgrade my grease guns for a while now but been putting it off trying to decide weather to get a milwaukee cordless or a couple of good manual guns. With most vehicles lacking grease zerks I just don't think cordless can be justified as a home mechanic. If I had a skid or mini I could see cordless since there are a dozen or more fittings on a machine.
