sick467
I have been using wood heat for the last many years and it's time to out-grow cutting firewood!
I think I want a propane heater as my house uses propane and that would be convenient.
I hoping to learn enough that I can size the unit correctly and install it myself (with a little help from my friends). I'll start by asking how to size the heater with the following information...
Facts:
My shop building is 50x50 with 12 foot ceilings, 2x6 insulated (R19) walls, R30 in the ceiling, and concrete floor. My workspace is a 30x30 corner room in this building with an insulated 18' wide garage door and is where I spend most all of my time (same insulation values as the building).
Goals:
I want to be able to turn the heat on in the work room and be taking my jacket of in 10-20 minutes (starting at 40-50° and getting to 60-65° in a short period of time). My oversized wood stove has spoiled me, I guess.
I want to easily get the temp up to 75° and maintain that in the workspace. I rather enjoy working in a T shirt in the winter hence the summer time temps that I am after.
On occasion I will want heat in the remainder of the building and I currently put a fan in the workspace door and circulate the heat out to that area. It is not important to get that area overly warm, just not cold (55-60°). This is easy to do with the wood stove as it can get the work room up to 90° with a few more sticks of firewood. At times, the work area gets too hot and I use the doors leading to the remainder of the building to cool off the room.
Concerns:
The web guides I have found warn about oversizing the unit, but it sounds like that's what I want. I am used to the wood stove and the shop seldom goes more that a day or two without me heating it up.
I am also concerned about the noise. I want it as quite as possible.
Questions:
Would it be more efficient to size the unit for the room and just keep it set at 60°, turning up for the weekend to 72°? OR would it be better to oversize it some and treat it like the wood stove...turning it on when I'm there and off otherwise? I spend a couple hours there in the evenings and most all of the weekend.
Bottom line (after all that wind I produced)...where to start with respect to sizing the unit?
All ideas and advise are welcome!
Facts:
Goals:
Concerns:
Questions:
