I need a horizontal bandsaw...
Jason280
I've had a Taiwan manufactured Rockwell(?) 4x6 horizontal/vertical bandsaw for at least 7-8 years, that was probably already 5-10 years old before I bought it. Its been a decent saw, never too impressive, but I was able to pick it up relatively cheap off Craigslist. Well, it finally died on me the other day, and it may not be repairable (I'm not even sure I want to fix it at this point). The gears in the gear box have gotten so out of line that the teeth won't properly mesh at times. It could be something simple, such as a bushing or bearing, but that will be a project down the road (if I don't toss it in the trash).
So, I am in search of a replacement 4x6 bandsaw that I don't immediately need to start tweaking out of the box to get it to cut straight. What are my options? I've been looking at the Jet models at Northern Tool, but not sure if they are worth the extra coin over the Northern or HF version.
Any suggestions for a decent saw under $4-500?
ken w.
Western New York
In my opinion,there is no difference between the Jet or the HF band saw as I had both of them.Both made in Taiwan or China. The HF had a better stand than the Jet. I got rid of both and bought a Wells saw # 5 on CL. If you have extra room you will never be disappointed in investing in an older American made saw.
Ign
Butte Peak ND
JCByrd24
Bath, ME
The Jet and a few of the higher priced ones are actually 5x6, the upper arm casting is different. My Jet cut straight right out of the box and to this day if the blade I'm using is good. A bad blade will not cut straight even in the best saw. I really only bought the Jet because it's what I could get locally vs ordering though, and at the time I believe the cost differential was less than it is now.
J
Jason280
Hmmm, not sure a bandsaw in Denver helps me a whole lot...;)
http://metal.baileighindustrial.com/band-saw-bs-128m
This one looks very appealing. What is the biggest difference between it and the Northern Tool model? Do you know if it is American made? Haven't had much time to really look through the link, but it looks like it would fit my needs perfectly.
dr_clyde
Holland, MI
I wouldn't buy a thing from baileigh. I bought a cold saw from them. It is such a *************. A friend of mine has several of their higher end tools and none of them impress me. I can't image their cheaper stuff is even worth looking at.
I would hold out and try to find a used industrial saw. They never die. An old Kalamazoo or W.F. Wells would be perfect for a home shop.
IMCA38
Bennet, NE
Do a search on Google or Yahoo for Olson 9x12 bandsaw.
These things are industrial strength.
If you can find one at an auction or estate sale, look to spend between $200-400 if it's in decent shape.
kazlx
Tustin, CA
The johnsons are awesome. My buddy has one. They just aren't the most compact things. My next saw is going to be an Ellis 1600.
t.ruckus.rex
That's the main reason I'm selling it, I takes up a lot of space
Rated for 10" rounds and up to 18" flats!
