I need a low profile jack ....
Pho20
That works on gravel and dirt. I change wheels/tires on my 2013 Subaru BRZ in my drive way driveway is dirt/gravel so all of my rolling jacks dig in and the jack pad starts to slide out from under the jack point. I have been using the widow maker in the trunk and last night it failed. So I need something that’s low profile able to be used on dirt/gravel lifts straight up and can utilize the factory pinch weld
I have up to $500
TIA
tomtomgt356
*******, GA
Druder
Yeah low profile and offroad really don't go together unless you improvise. Harbor Freight has a really low profile 2 ton and a standard low profile 3 ton in the $80-120 then they have their Daytona 3 ton for $180 when you catch a sale like this coming weekend. Snag a half sheet of plywood and an adapter and you'll still be under half your budget.
achirdo
Dallas Texas
Highly suggest the harbor freight 3 ton Daytona. Surprisingly great quality from harbor freight. Honestly probably feels like the most well made product in that entire store.
Farmall450
Marengo, Illinois
I also suggest the Daytona from HF. Had mine a year now, very nice. Excellent fit and finish plus low enough to get under your car (it goes under my friends miata No problem).
Druder
Also, a full sheet would hold the jack and two jack stands if you did one side at a time. Jack stands are important (mandatory for me) all the time but especially since you're working on a soft, uneven surface.
P
Pho20
3/4 is probably your best bet, this is not a less is more type scenario. Just don't get cheap **** because it will crumble.
Awesome thanks this may be the first time gj has saved me money :)
Wamsutta
Amarillo, Texas
The most important part is the pad size that contacts your car. If the pad diameter is too small, it's going to put a dent in your car. Try to shoot for a five to six inch diameter pad.
ovrrdrive
Central Florida
What thickness plywood should I get?
I'd grab a piece of 1/8-1/4" steel plate if I were you. if your car sits as low as my son's mustang a sheet of 3/4" plywood will make it too tall to go underneath. We have to drive it up on 2x4's to get the jack far enough under it to get to a good lift point. I have the regular low profile 3 ton jack from HF. their jacks are made well. I recommend it too.
Druder
That's actually not a bad price when you consider what plywood costs. Then you just have to come up with something to support your jackstands. One word of caution and this was most likely an isolated incident, I bought my father a 3 ton low profile from HF and it has two different casters making it wobble. It's getting exchanged today but it may be worth checking out in the store before taking it home like I did.
jml74
Yeah, jack stands are the way to go. I've used them on gravel with a piece of plywood underneath cut big enough to provide a platform for the jack stand. I'll do tires and brakes that way, but I wouldn't get underneath it (it's stable, but I'm pretty conservative when it comes to having a car fall on me).
wretched73
You could always weld a piece of steel to the bottom, just like the jack skid
apollo11
State Of Reality
or these
https://www.quickcar.com/64-088-Floor-Jack-Dirt-Wing/
Druder
That's what I have and I love it, but not everybody knows a welder so I'm hesitant to offer a solution that isn't store bought. Great suggestion.
P
Pho20
so basically i just need to weld a sled onto the bottom of the jack?
48RON54
Inland Empire, CA
I'm impressed that 90% of this problem will be resolved with a piece of plywood. I feel dumber for not having thought of that lol.
