I need a PCB vise. Recommendations?
Grant Gunderson
Bellingham, WA
I got a bunch of small PCBs to work on as well as small connectors to de/ re pin. I got a ton of high quality vises ranging from a Wilton 3C, 5” dawn offset and a 4” Starrett and Reed 3C. But none of them are the correct tool for this job. What’s the best option for doing PCB work and holding connectors to re-pin? This will be a dedicated work station as I have a lot to do. Quality matters.
That’s 13mm wide, so it’s tiny.
The boards are mostly 1x3 to 4x4” or so. Here is a few examples.
Thanks in ahead for the recommendations !
PCustoms
VT
Panavise for the cables?
Can't recall ever seeing a vise used on a PCBA. Well, one time, but that was a *********** hail Mary repair and I can't believe any of them worked after
How many are you doing of each type? Maybe some static dissipating material, a few standoff and some screws to make a mounting point. I suppose you could then clamp that in a vise if needed.
imag2753-X3.jpgI’ve got one of these, would not recommend for anything that small. But might be nice for holding the other gizmos holding your PCB, showN above,up off the deck.
G
Grant Gunderson
Bellingham, WA
After a bit more thought I think I’ll machine a fixture jig to hold the connector but still looking for a great small work vise. For electrical stuff.
duneslider
Riverton, Utah
I have the Hakko Omnivise, a panavise, and one of those magnetic helping hands with a bunch of different options for holding things as well as a few others and I wouldn't say any one "the one". But, I do probably use the magnetic helping hands one the most because it is so flexible in what it can do. I also use the Hakko omnivise a lot because it is so compact and easy to use. I leave the hakko in the garage on my work bench for the general junk I do out there. The others are all for my inside workbench (which doesn't exist right now so everything is in totes).
I used to use the panavise a lot and still really like it but the magnetic helping hands has kind of taken over for me.
rlitman
Long Island
I like the ones like this that lay flat on the desk, the ones that hold it in the air all seem unstable to me.
Agreed, but they're mainly suited to rectangular boards. I've used my Panavise for some board work, but mainly place boards on a silicone mat. On similar work where standoffs are called for, Cleco makes clamps that work well. I'm not sure a Cleco would hold safely in the drill holes, but the clamp style can be pinched onto carefully chosen spots around the edges and used as temporary standoff feet.
Superdavey
Canada
I have a little record vise like this one for circuit board work. Made in England , although the one I bought looks to be one of their later productions considering the jaws don’t line up fully parallel … but holds circuit boards well, front jaws can be moved to the rear for greater width
banditbigdog
Southeast
Those boards look pretty small.
Fabricating something like this would probalbly be too large.
Take a rubber finger lab clamp:
Remove one of the the fingers:
Attach it to a NOGA arm, does not necessarily need to be the on pictured, you could fab something else to hold the clamp a bit more securely.
Use 2 of those and make a 3rd fixed hard point.
Or just make 3 of them.
Cons:
Not inexpensive to make 2 or 3 of these.
May require repositioning 1 or 2 of the arms when removing / installing a board.
May be too large for your purpose.
