Here is my batting cage I am building. The footers that support the poles are 12"x12"x13'. When we first winched up the net, there was a lot of tension on the poles and they lean in bad and actually started to move one of the footers. One of the bolts on the bottom of the poles sheared. I was thinking of replacing the bottom bolts with the same pins I use to unpin and fold the cage poles down. I dont have much room behind the poles to run a cable from the top of the pole to a concrete anchor point. Does anyone have an idea how I can fix it to make it work?
