I called them to see if they could give me any information, and they said it was rejected because it falls under the city of St. Charles code enforcement/permitting jurisdiction. I went to their site and looked at what I need. Holy cow! I am at a loss for words! I thought this was going to be a simple weekend project. I might spend $200 on it and half of that was for the LVL's. I have all the other hardware and lumber I need for the project. I figured I would build a temporary support for the roof, frame the door in the rear wall put up the LVL's and then be done in one long day. That's the way I would have done it... Maybe the requirements are typical, maybe it is just a shock since it is my first time doing a project where I need a permit. But I don't understand why they need half of this stuff. 14 pages of stuff!. I am sure that a lot of it does not apply to me, like the sewer ect... But how do I even begin with this process? the parts that look like they might be needed for me are
IMPROVEMENT PLAN APPLICATION CHECKLIST
All Improvement Plans submitted for a permit shall address the following items on the plans for review by
the Department of Public Works. Applicants shall check off each item provided on the plans. Attach a
separate letter explaining reasons why any item below is not provided for on the plans.
An up-to-date version of the City of St. Charles, Missouri Code of Ordinances can be found at Sullivan
Publications.
General Information
Plans shall be submitted on 24” x 36” sheets (Preferred)
Address all conditions of the Planning and Zoning Commission approval.
All plan sheets shall be signed and sealed by a registered professional engineer.
Show the locations of all existing entrances on both sides of the street, within 300 feet of any
proposed entrance.
Identify the property by lot lines and location, including dimensions; angles and size, correlated with
the legal description of the property.
Show natural features such as trees, streams, rivers, lakes, drains, topography, and similar features.
Show existing manmade features such as buildings, structures, easements, existing utilities such as
water and sewer lines etc., excavations, bridges, culverts and drains.
Show location of the site and its geographic relation to neighboring properties showing all adjacent
buildings and roads within 100 feet.
Include existing topography a minimum of 50’ outside of property lines.
All sign locations and sizes must be approved separately. Remove any sign references from the
plans. Any proposed signs located on plans should be noted that their size, type and location are to
be approved under a separate submittal.
Include a north arrow and scale on all plan sheets. The plan sheets shall be drawn to a standard
scale and should be uniform. The north arrow should never point to the bottom of the page.
Proposed improvements should stand out from existing conditions on the page by using bolder line
weights.
Provide a legend on all plan sheets and others as necessary.
Show all utility relocations.
All street lighting shall be Ameren approved/supplied LED lighting.
Dimension all non-typical features.
Provide traffic control plans for construction within existing roadways. Include accommodations for
pedestrians where necessary.
For new developments show survey ties with coordinates. At least 3 ties are required.
Developments may be required to submit a traffic study showing the impacts to public roadways.
Upon final approval a sealed set of plans shall be submitted in *.pdf form on a compact disk. Format
of the *.pdf file shall be in accordance with City Requirements.
Cover Sheet Information
Provide a location map of the site with north indicated.
Indicate the USGS benchmark used for all survey data. All topographic data shall directly relate to
USGS data.
Provide a basis for bearing to establish how north was determined. Show north arrow on all plan
sheets.
Use MO State Plane Coordinates. Zone, Datum, Projection
List the City of St. Charles General Notes on the cover sheet.
1. All improvements constructed herein shall comply with the Code of Ordinances of the City of St.
Charles.
