i need ideas
pudgybear
Brooklyn Michigan
I am starting to build garage cabinets from 2x4's and plywood, i have the tools and the know-how but what i need is the ideas/plans on how do i construct the framing for the base cabinets, anybody got any pictures & ideas,,,,,,, the base cabinets i want to have a mixture of doors and drawers, i mainly need the ideas for the framing!!!!!!!!! thanks for any help you can give me
geologist
You'll probably want to rip some of those 2x4's into 2x2's.
csp
Franktown, CO
YOu need to add more details for the info you're looking for.
Determine the size you need to build, construct a frame, skin with the plywood. No need to make it more difficult than that.
Depending on the plywood thickness, and the tools you have, a frame may not be necessary. Cabinets are just boxes with one side open that you hang a door on.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Check Kregs site for projects. I'm sure there is enough ideas to get you going. http://www.kregtool.com/project_plan.html
I'm on the wrong computer at the moment, but when I had wood cabinets in my garage, I built a 2"x4" framework, then made all of the fronts from !"x3" pine. The top cabinets I made from 1"x12" pine shelving, with 1"x3" fronts. The doors.....I found a place that sold seconds for $5 a piece. Nothing wrong with them except maybe a misplaced hinge pocket, wrong grain, just some subtle little differences. If I remember, when I go in for the evening, I post some pics.
For starters though, I'd check out Kregs, then do a search for some other woodworking sites. Also when you're at the store, check out Family Handyman or some of the other popular woodworking mags. They usually have some great storage ideas.
bigguns69
Iowa
Here is a sketch of 3'x4'x16" deep wall cabinets that I built out of 3/4 sanded plywood. This is by far the cheapest way to build strong basic cabinets for shop or garage use. I attempted to buy used cabinets from craigslist and the local Habitat "Restore". Everything was too expensive for the volume enclosed. Painted mine white and good enough for the shop.
bigguns69
Iowa
Try agian on the sketch attachment.
  • wall cabinet 1.pdf
