y5e06
Well,
I've reached my limit and tolerance for the compressor I currently have.
Normally that wouldn't be a problem since I'd just go out and buy something proper. I'd really like to run my air tools (small cut off wheels, body saw, angle grinder, air drill, etc) w/o experiencing the dreaded pressure drop or even try to run sanders etc if I could for doing body work. However, I have no space....
I live in OK sized house but I have a very small back yard, a small 2-car (380sqft at best), and no spare nooks or crannies.
I have to leave the garage so that, if I move items around, I can still fit two cars if needed. Right now its about at its limit w/ surrounding shelving, work space, storage, etc
I've been trying to think of ways or places to squeeze in a good quincy 60g or similar. I just don't think i have the space, certainly not in the garage.
attached are pics of my current portable Husky 2hp 26g oil bath compressor (a campbell hausfeld as far as i can tell) I have in my laundry room. it makes loading and unloading the dryer a pain.
Options are:
1) do nothing
2) move to a much nicer house w/ a proper shop which, of course, we cannot afford
3) figure out how to upgrade my current compressor
3a) upgrade pump & motor to 3-5 HP 10+cfm @90 hp, leave on the portable tank, rewire laundry room for an extra 220V for the new motor.
3b) upgrade as above but buy a gas dryer and use existing dryer 220V for compressor (my laundry room is both 220V and natural gas). Dryer is currently 220V.
3c) plumb an auxillary air tank in, but that does not improve my pump output. and I'd have to run a higher pressure line to take advantage of it (pre regulator). say a 60g in the attic (w/o motor/compressor etc) but my attic is not rated for storage loads and I already have enough car parts up there that shouldn't be. typical tract home. I don't think i'd want or could put a full compressor up there. and in the end i'd probably end up lacking on air supply anyway...
4) stackable washer and gas dryer w/ the compressor in current dryer spot- i looked into this. new unit sets are $1500-$2K. sheshhh. no way. and also my laundry room isn't deep enough for new units. only 30" from my door jamb to the wall. most dryers are 29-32" plus the 3-5" for ducting, wiring, hot/cold hoses, etc. I wouldn't be able to get the door open! my current old school top loaders are damn reliable too. at 25" plus the 5" of accessories it barely fits. No way I'd go to an apartment sized unit.
5) locate it outside. well, my side neighbors are about 20' from my sides and both have bedrooms adjacent so that would be quite rude to run a compressor at who knows when. I'd have to build a shelter too to shield it from the elements. these 60g units seem to all state to locate indoors too. I'd need to run 80+' of cabling for the 220, tap into the main box etc. I don't feel comfortable going into my main box myself either. there is no main breaker/switch.
5a) locate out back. my back yard is small. I'd have to build a shelter. the 220 run would only have to be 10' or so but then i'd have to run 60-100 ft' of iron pipe or that blue plastic tubing through the attic rafters of a vaulted ceiling house, over the main living area, to get to the garage.
None of these options seem reasonable to me.
The upgrading my current compressor seems interesting at first but then i have to throw out all the good usable parts on mine, add more $, hope for the best, and then still be left w/ a low volume tank.
My current one is similar to many you see available. It is 'rated' at 5.5cfm at 90 and 135psi. It can't even supply enough constant air to run my plasma cutter for more than 5 seconds. When i look at the tank mfg tag it looks like its really rated at 175psi? is that the safe rating? can I bump my storage pressure up closer to that? is the 135psi purely a limit of the lower end pump? If I stay w/ a tank in its current location I have to leave it portable. the HVAC door is adjacent and I need access to that when needed.
I went as far as ordering washer/dryer on black friday w/ the fantastic deals. but i ended up cancelling it when i realized the fit was absolutely too close to call. I could end up w/ $2K in appliances that don't fit my space and no compressor. Used ones are an option but I don't trust the reliability of used stuff like that anymore (i'm getting old, i guess)
ignore the garage mess. its no 12ga Garage...
there is about 6" from right side of the car to the workbench/shelf w/ tools. at the right front is a hydraulic press and horizontal/verticle band saw.
2" from nose of car to shelving. w/ a 2nd car there is enough room to walk down between them but not much more. Work bench space and took box on the left side, front. and barely enough room to get out of the car and walk up or down on the left side w/ the 2nd car.
Normally the red car goes on the left w/ enough room to work on it etc.
any solid ideas?
Options are:
1) do nothing
any solid ideas?
