I need some hose fittings....
STGFordCrazy04
St. George, SC
OK,
I need something like this but Id like it 1 1/2 x 3/4
and I need something like this but without the on/off valves.
both need to be brass or stainless. Anyone have any idea where I might find something like this? Local stores and as best as I can see on the internet has proven unsuccessful.
Are there any quick connect all metal garden hose fittings that are worth buying? I need this 100% leak free.
LXCam
If they make it, McMaster Carr will have it or at worst you can piece it together with fittings, couplings, ******* and a Y.
STGFordCrazy04
St. George, SC
McMaster and Grainger have such a huge selection I may have overlooked them.
Ha...what Im doing....
go from this
to this
and then split to this
I have AN fittings and -12(3/4 id) stainless braid to go from the motor plate to the pump but I need a way to connect 2 hoses to water hose thread. I know the ID of the pump is threaded to 3/8" npt but thats too much of a bottle neck. All of this can be done with AN fittings but thats about $200 of shiny aluminum I dont really care to spend.
Yes, I know the temp rating on this pump is 140*.
Yes, I know its not meant for cooling an engine.
Yes, I know it will work.
No, you cant talk me out of it.
:D
premierplayer
Maryland, USA
Garden hose connections, 100% leak free :lol_hitti
good luck with that, brass, SS or otherwise
what you are looking for are 'barbed' fittings, they are available, MSC, McMaster & Carr, keep searching, you may need 2 pieces to get from 1.5" to
.75"
pressurewashersdirect.com has good prices on snap fittings
LXCam
Well then just hodge podge it or go up the a -16 n the hose will fit the a barbed coupler. I have the same issue right now on a build using a mazier pump, but I'm maching the y fitting for it and both port fittings have to relocate for the blower belt, fn pita.
LXCam
I don't have any on this phone or hosted with those details. But I can this weekend. I can give you a photobucket addy you can see the build if your interested.
