I need to make a battery riser
Exceller8
Banning, CA
I just purchased an optima battery for my 2008 Nissan titan. It came with a plastic riser to raise the battery to the correct height. The problem is the riser is cheap plastic and I can't secure the battery unless I modify the existing riser.
I would like to make a new riser and would like to know what the best materials I can safely use for this application.
Thanks in advance for your help! :beer:
JJThrasher
Indiana
Wood works and is non conductive. If you use metal make sure it won't ever short the terminals.
E
Exceller8
Banning, CA
Thanks! :thumbup:
I wasn't sure about wood, so I thought I would ask you guys before I made a stupid mistake. I figured metal was out because my terminals have no extra room to move around and that would put them too close to a metal riser.
Any other options besides wood?
CJM8515
2x6 under the battery. Non conductive and cheap. Metal is nice but requires fab work usually.
LXCam
How thick does it need to be. I have a bunch of switchgear insulator material in both sheet and formed channels you're more then welcome to have.
scooz14
do yourself a favor and return that optima. nothing but problems lately
E
Exceller8
Banning, CA
What issues are you finding? I did some research and the Optima's still got good reviews. I did read some old threads from 5 or 6 years ago where people were complaining about them.
I haven't measuerd the exact height needed but I would say 3 or 4 inches.
Capt Chrysler
Middle of nowhere.
Optima batteries did have a short life span here a few years ago. I have had some go as long as 10 years. Then I had a Red top die in 2, Replaced it with a Napa NASCAR Gel (was told it's the same as a red top), it didn't make it a year. Back to a red top that went 6 years. I still run them in the wife's daily driver & and the street rod. This is the first winter I have ever pulled the battery (red top) out of it. We will see how it goes this week.
Capt. Chrysler
paranoid56
San Diego, Ca
i have a bunch and never an issue. but i also dont let them sit dead either. all stay charged and still running strong.
kkroger
Just Order up a hunk of HDPE from McMaster or Enco or??? and cut it to fit...
Will look a LOT better than a 2x6 in there... and last longer... Or some Synthetic Wood Decking...
Vegaman_Dan
Pacific, WA
White cutting boards. Easy to cut with wood working tools, insulate nicely, aren't affected by solvents or battery acid. Makes a nice simple space under a battery.
I use them when making insulated terminal blocks for jump point on my utility vehicles.
