ptgarcia
I'm going to have to replace the load center on my house before too long. The existing load center is one of those crappy Zinsco units from the mid-70s flush mounted in the south exterior wall of my stucco house. At the same time, I'd like to run conduit/wire clear around the house to the north side where I want to install a 60-90 amp sub-panel on the attached garage wall. I also want to run a 15 amp circuit (or 2, if needed) along the lot boundary lines (rear and side) for landscape lights, speakers and other low draw items for entertaining (radio, movie projector, etc). That circuit will start there at the main panel, run south underground 15' across the side yard to a block wall, and run along the wall face around the lot.
Looking at the attached picture, how is this accomplished? Is the existing load center removed, and the new one installed in the same recess (with some removal of the stucco as required)? Or will a new load center be surface mounted over or adjacent to the existing unit? If it matters, on the other side of the panel is my living room (in the last photo, behind the lamp in the corner of the room), and the attached 3-car garage is on the opposite side of the house. Also, I'll hire a licensed electrician for this job, I'm just curious how its done.
