I need to torque a crankshaft pulley
jal395
Raleigh, NC
I need to torque a crankshaft pulley but have no tool to do it. I am either going to make a spanner type wrench to hold in the openings of the pulley or a strap wrench with the old belt. Anyone done this or have any advice? I have access to a welder but no machine shop.
Catamount
New England, USA
In the past I've taken some scrap steel and drilled 2 holes to match pulley bolts on the crank pulley.
The steel gets propped against something else in the engine bay and lets you torque on the crank bolt as much as you like.
rsanter
visalia ca
What engine?
Do you have access to the teeth of the flywheel (like on a chevy)
If so they make a flywheel holding tool
Google what you are doing to see what tips the pros have
Bob
jacked_72
I used the old belt to make a strap wrench on a Mercury Villager. All I did was take a piece of 2X2 I had laying around and twist the old belt around the wood until I couldn't twist it any more. The wood was long enough that it rested against the garage floor. It worked well enough that I could torque the pulley bolt. It took a couple of tries before it "caught," but it did. I was surprised that it worked at all, but it sure did.
If you are doing a Honda, I notice that Autozone has a loaner tool for this job. You might check it out and see if it will fit for your application. On my V6 Toyotas, I bought the crank pulley holding tool from Schley for about $50. I've used it 5 or 6 times, so I got my money's worth.
JASTECH
Gering, NE
If it's a stick then I put it in gear, set brake and block wheels. Then you can torque on the crank bolt.
J
jal395
Raleigh, NC
97 Mazda Protege - I don't remember the engine but it's the smallest one. I'll see what scrap is laying around and then decide. I'll let you know how it goes.
Charles (in GA)
50 mi south of Atlanta
To be quite honest, I doubt that many crankshaft damper/pulley bolts ever get torqued after the first timing belt change. I know that my Ranger had some crazy out of this world torque that took a 6 ft cheater bar and a huge pipe wrench to get off the first time. After that, I just crank it down good with a 1/2 drive ratchet and forget about it. Never has worked loose and the second and third times I did the timing belt, it was a breeze to break it loose.
Charles
J
jal395
Raleigh, NC
Engine was in the car still, this was the last bolt before the wheel lugs, oil change, fill with coolant and crank it up. My mechanical engineer dad made up a tool. two pieces of 1 inch angle iron bolted back to back and then spread apart. A cap screw and nut on each end and presto.
JKady
Spanaway, WA
If I can't hit it with an impact, chain wrench around the pulley usually gets the job done (And before the cries of "That ruins the pulley!" start, no, it doesn't if done correctly)
csargents1546
Westminster CO
The first and last time I asked about the torque on a crankbolt, the guys in the shop laughed at me and kept going. Since then hit it with and impact and make sure it lines up with the other pulleys and call it good. No problem at all. Post some pics of you holding device. Sounds like a good design.
jacked_72
I've been on the receiving end of the guys who "hit" it with the impact. Geez, I've had them on so tight that I didn't think they'd ever come off. Based on the cheater bar I had to use and my weight, I'd estimate easily 600+ pounds. Not even the 3/4" HF gun would get it off. I torque them to spec, which is around 160 ft pounds on my Toyotas. When my lat one hit another 100K and it was time to pull it off again, my wussy CP 1/2 gun took it right off. So, anyway, I use the torque wrench; its a free loaner from Auto Zone or O'Reilly's.
You guys ever use the "starter bump" method to remove the bolt? I've never had the nerve to try.
greasemonkey44
memphis
i have; it is effective
but terrifying at the same time
usually i take them off and put them back on with an impact
the most stuck ones ive seen are the ones 100k from the factory
byoungblood
Berryville, VA
I did it on a 2.3L Ranger I used to own when the timing belt broke as soon as I got to the end of my driveway...at the bottom of a hill. Having air tools does you no good when you can't get to them, so I just got out my 3/4" drive sliding bar and cheater, put a socket on, and turned it by hand until the cheater was touching the pavement. Bumped the starter, heard a clang from the pipe falling off, and viola! It broke it loose.
jethro29
central delaware
so you did the timing belt job at the end of you driveway? at the bottom a a hill?
Sh1thead
Philly :(
Ratchet strap wrapped twice around the pulley and then to something sturdy. Works everytime I needed it to without digging through 50 tool cases to try and find shop tools.
franzdom
NC
Charles
Just because they aren't torqued with a torque wrench doesn't mean they aren't torqued :lol_hitti
JWink
If its the 1.8 liter BP engine flyin miata makes a tool for the job. I think I'd just make one like you said though.
bart1
Alabama the Beautiful
I just did belts on my car. Torqued my bolt to spec, used a flywheel lock in place of the starter. That's why I work in my cars and why I have 255k on that one. ;). Seriously, a flywheel lock probably isnt too expensive.
