Ok i got the lift up and running....but when i poured the concrete i FORGOT to put in my pulling chains i had ready to go. It was a long day and i had to put in floor drain ect. anyway i have a great lift but no way of getting a disabled car/truck into my garage by my self!!!. I have 5in slab with fibermesh and 4500 lbs mix, i though about using those chain pots they can take 10,000 lbs of pulling for straighting cars ect, but they recommend at least 6in of crete. And id like to be up in the air with my winch so as not to drag /winch over the top of my lift (4 post) maybe chain down a 2inch receiver type mount to the pots?? The walls are pole barn style i could prob bolt a steel beam to wall but dont wanna constantly re spackel when the sheet rock is in. I used a 4x4 post today at the inside garage door frame to cheapo winch and cabled the winch to the 4x4... it worked but was really bending the 4x4 and only got me to the opening of the door/apron. Its getting inside thats gonna be the trick. My good winch is a 10,000lbs with 100 ft of cable mounted to winch plate and then welded to a 2inch receiver so i can pin it in any 2in receiver hitch. Remember the lift is Not bolted down!! free standing, and its a slight grade upward to garage. any ideas would be great thanks.
