Ironhead709
- Joined
- Sep 5, 2013
- Messages
- 3
First off,i have been working a lot of OT in thr past year so I have not used this in a while....
And i also did a search and read about possibly being the check valve and/or being too thick of oil in the cold...
I changed the oil today,and it wsa THICK compared to the old,i put the recommended I/R Select synthetic in it,still does the same thing'
The Problem.........
It will "Hum" and either move very slow or not move at all and then trip the motor safety breaker,on the motor itself
I took the belt off completely,turned it on,and......it will still "hum: and move very slow for a few seconds,then kick on and run perfect..this is with no load on it at all,belt completly off...sometimes it will be longer kicking on to full power than other times.
As sort of process of elimination,i put the belt on as loose as it will go,so it would slip and see if the motor kicks on..it did,still with a hum and slow moving,then kick immediatly up to speed,then as it was running,...i tightened the motor up and it ran the compressor pump just like it should...i let it air up to max,it shut off like it should...i pulled the release valve so it would kick on again.....still the same thing...Hum noise,moving slowly and trips the over heat switch on the motor.......
So i am guessing either a capacitor..or i remember someone saying take the front cover off the motor off to clean some contacts?
The motor bearings in the motor seem fine,everything seems smooth and no play in the shaft.
Seems to me,there is something keeping it from kicking to full power right off the bat like i tused to,when it was running fine it never did any kind of slow start like that on the motor,even when it was real cold out and the oil was thick,i've had the belt squeel and compressor going slow,but the motor was at full power..tightening the belt solved that issue,but now i can't even get it to do that.......
Capacitors?..or some kind of contacts inside the motor?
