ratrodder123
Well, I started this thread in the heating and ac forum but havent gotten any further direction, maybe someone here can help me out. Bear with me.. I have a block wall garage in pennsylvania. I put plastic up on the walls and studed with 2x4's. The 2x4's are not very far off the wall (1/4" at the most). I purchased fiberglass faced insulation and drywall but havent put it up yet. I now know the plastic (vapor barrier) is on the wrong side and after 4 months have mold spots on a couple damp spots on one of the walls.
Now what should I do to correct this. My thoughts were to cut the plastic out and remove it in the stud cavities but leave the remaining plastic behind the studs. Then put 1/4" foam board sheathing thats perforated and breathable (lowes item# 304092) in each stud cavity followed by the rolled fiberglass faced insulation and then drywall. This garage is detatched and it will only be heated when I am using it here and there on the weekends. What do you guys suggest?
