djjsr
My workshop is a 100 year old brick building. The previous owner was an electrical contractor, so I've been assuming that everything electrical should be ok, but it appears I have a problem that may be serious.
It looks like all of the lighting and 120 volt wall outlets are grounded using the emt conduit as the ground. Everything seems to be working ok and I used one of those little yellow plug-in testers and everything tests ok, but it just doesn't seem right to me.
I've been told that using the conduit as the ground was common at one time.
For the professional electricians, my questions are:
1) Is this a dangerous situation that needs immediate attention?
2) If I have to run ground wires, should they be solid or stranded, bare or insulated? (everything is in metallic conduit).
Thanks
Thanks
