With my 3.2hp 10.2CFM @90PSI rated 60 gallon husky pro compressor with 100psi line pressre and 26.5 psi into the HVLP gun which requires 15cfm at 40psi I measured 1.82 minutes of spraying time before the compressor turns on again. I have a 50 foot 3/8 hose from the wall regulator into a gun filter and then the gun regulator.
I need to time how long it takes to refill the compressor tank but I think this is not going to be enough to paint my car.
How can I improve the setup I have?
My thoughts are:
-Replace the 50ft rubber air hose to the gun with some copper air pipe along the 30ft wall.
-Reduce the number of reducers between the compressor and regulator and regulator and air hose.
-use high flow fittings like milton V
I am thinking this may increase CFM but not increase spraying time.
Finally I could get a lower CFM spray gun or spend $1500 on a new 80 gallon 5hp twin stage compressor which I obviously don't want to do.
My thoughts are:
