I used thread loc on nyloc nuts.
sdguy55
Pierre, SD
No need to replace it. Just a little more added security to a nut that was built to be added security
MadMechMaster
Frankfort, IL
Some threadlockers will dissolve/react with some plastics. you should see this rather quickly. You should be able to check this for the grade you used.
Anyways, you have some threadlocker on the threads, and that should be enough.
NUTTSGT
Northern Central Ohio
Belt and suspenders.
LOL, Sorry but I found that funny coming from a guy in an urban area like LA in Southern California. Generally only the older skinny farmers do it around here.
:lol_hitti
To the OP, you should be fine. If you want the extra protection, next time I might suggest some clear RTV.
pepi
Woodstock, GA
I am surprised it even had any affect, did you try to remove the nut? As said above it would dissolve fairly fast is it was going to.
JakeKohl
Greenville, SC
It's not a big deal. The loctite will reduce or eliminate the nylock's repeat use but it won't affect the ability of the nut to stay on until it is removed later. Most of the loctite affects on plastics is not a chemical reaction but issues related to the additional pressure the loctite adds when it cures - it tends to crack/relieve the plastics. We used to have a lot of issues with this on lexan guarding on machinery I used to help design/develop. Our assembly guys would think they were taking on extra thorough preventative step by adding loctite to the nylock hardware that held the plastics in place - but it would make the guards crack at the bolt holes some time later.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A fellow worker when I was in the Toolroom made a 1.2" thick Lexan cover and he didn't want the bolts to loosen up. He used Loctite on all of the screws. Went to lunch, came back a half hour later and the Lexan was all split everywhere. No one would have noticed it other than it was clear Lexan. I was really surprised it did that. BTW, is specifically states on the bottle that it will react with certain plastics.
Kevin C
Portland OR
I have never seen a reaction between Loctite and nylon. As others mentioned, polycarbonate ( Lexan) and Loctite is a really bad combo.
Even glass filled polycarbonate will crack and disintegrate.
JakeKohl
Greenville, SC
I spent some time researching that and some documents I found on the Loctite site pointed to the expansion of the thread locker with plastics leading to cracking...who knows.
Kevin C
Portland OR
Actually I do....
I have been using Loctite for a really, really long time. I also used to design optical encoders with plastic lenses. If you get oil from your fingers on the lenses and expose them to heat and humidity your a lot more likely to get cracking. Sunscreen will do the same thing. Get them near Loctite and they will run away screaming.
Two months ago a little bit of Loctite spilled from a container and left a wet film on the bench. A plastic foot of the test instrument got a tiny bit of Loctite on it from sliding across the bench. Three weeks later the plastic was crumbling.
Same thing happened to the glass filled polycarbonate housing I designed for optical encoders that were held down with loctited screws. Nice stress cracks in the plastic from being attacked by the thread locker.
Don't get me wrong, great product but you have to understand its limitations.
JimVonBaden
Northern Virginia
No, the nut will not fall off. However, when you remove it you will need to replace it. Nylocks are designed to use the nylon to hold the nut in place. That nylon is likely useless for this now. Once the threadlock is broken loose, the nut will never be any good without threadlocker again, and there is some concern as to what the interaction of the nylon with the threadlock will be.
Personally, unless it is a non-critical part, I would probably replace the nuts. But I am **** like that!
Jim :cool:
Twiggss
middle
learn something new everyday.
retrobuilder
Alpharetta GA
the solvents in threadlocker should not affect the nylock nut lock. Ny stands for nylon. while not impervious to some solvents and acids you should be fine. just do not use a threadlocker to strong a bond for small fasteners. also a great way to use nylocks used many times where the plastic friction fit wears down..
Kevin C
Portland OR
http://www.coleparmer.com/Chemical-Resistance
Handy chemical resistance look-up table. Unfortunately the don't list Loctite. I was able to conform that nylon is compatible with mayonnaise as well as gasoline. Its not very good with hydrofloric acid.
BTW... I found this on Loctites Q and A site:
A. Anaerobic adhesives are generally not used with most plastics. Anaerobic adhesives will stress crack some plastics, including many thermoplastics like ABS and polycarbonate. If the product is used for metal-to-metal but in close proximity to plastic, there is the possibility of excess liquid product or vapor affecting the plastic. In the case of compatible plastics like acetals, the anaerobic adhesives are simply not the best family of products for effectively locking and/or sealing. Often Loctite® Cyanoacrylates (Instant Adhesives) are substituted if they meet the other application parameters.
http://au.iloctite.com/en/anaerobic-adhesives-threadlocking-gasketing-and-retaining
