1/4 drive only.Use them all the time. Usual locations are when reaching thru multiple obstructions and where losing the socket or crows foot would result in significant time lost to recovering the tool. We have locations on the jets where losing a item in certain areas could result in hundreds of manhours of work to recover the item.
The other main time is where one is working on top of the aircraft and a loss of the socket would require going all the way down to the hangar floor to retrieve it.
The only size we use locking extensions and ratchets, is 1/4" drive.
I noticed that Snap on’s spark plug service kit included 1 extension. It is a locking extension.Spark plug sockets on locking extensions are the first specific application that comes to mind.
I’ve never actually had a problem with a normal extension.
But if they use that locking extension in their kit, then it must be common for folks to prefer that.
1/4 drive only.
Don’t see too many 1/4 inch drive crow foot out there.
This is the only real reason I have a set, though they have come in handy a few other times over the years.Spark plug sockets on locking extensions are the first specific application that comes to mind.
What brand are your 1/4" drive crowsfoot wrenches?Use them all the time. Usual locations are when reaching thru multiple obstructions and where losing the socket or crows foot would result in significant time lost to recovering the tool. We have locations on the jets where losing a item in certain areas could result in hundreds of manhours of work to recover the item.
I thought pin retention sockets were made for FOD and drop safety. At least those require a punch to depress the pin to release. If dropping a socket required hundreds of manhours of work (or was a life-safety issue), I'd insist on safety wire...Use them all the time. Usual locations are when reaching thru multiple obstructions and where losing the socket or crows foot would result in significant time lost to recovering the tool. We have locations on the jets where losing a item in certain areas could result in hundreds of manhours of work to recover the item.
What size 1/4 drive crowfoot do you find yourself actually using? I’d guess just 8 and 10? Snap on goes 7 to 14Proto sells them, even in metric. And yes, usually I have a locking extension if I'm doing 1/4 crowfoot activities. As others said, when you're in a deep area snaking past BS is where they shine. Also if you have very rotten/worn fasteners and your tooling wants to stick/lock onto it.
I thought chrome was a FOD issue anyway, so that might help explain why pin lock is impact only. Safety wire a joke, but picturing a safety wired socket still makes me laugh.Rlitman: Pin lock stuff is for FOD prevention and other reasons. You find it mostly on impact stuff and for 3/8" drive and larger. We don't have a lot of pin lock stuff, as it's simply not available in the 1/4" and 3/8" standard drive world. We do have pin lock drives for our screw gun adapters, but the only thing we can use those on, is some of the manual drive gear boxes. We do have the button locking stuff for 1/4" drive, and some of the 3/8" and 1/2" ratchets have button locks as well. No real way to safety wire a straight socket to an extension.....
Here's one of the little shortys that we have. It takes keeping the button pushed to remove the socket. Simply bumping it, will not release.
Stahlwille 405QR QuickRelease Extension, 1/4", 54 mm | Stahlwille at KC Tool
Stahlwille 405QR QuickRelease Extension, 1/4", 54 mm Patented design DIN 3123/ISO 3316...www.kctool.com
There are locations on the airframe, that a loss of a socket or part can be extremely hard to retrieve. We used to have some borescopes with working channels, so we could use surgical instruments to find and grab stuff down in those locations....
Rebuild the interior through the sunroof and engine through the gas cap.For those that don't play airplanes, think having to gut the complete interior of a car, down to the sheet metal, including all the wiring, so that you could recover a lost item, then putting it all back. Oh, and don't forget that you have to have inspections prior to installation of each item as well as one after it is installed and that there is a bunch of paperwork that has to be accomplished at the same time.
This. COP. Ford 6.8L, Honda Aquatrax, Hummer H3.... recently.100% with spark plug sockets due to the deep recesses filled with coil on plug ignitions. My Toyota 4runner 4.0 for example.
the 3/8 crowfoot is just too big sometimes?
