IBC
Bigox
I have just brought a IBC pod and a IBC cage, can i cut down the cage two or three
rings and use as a stand to hold the IBC pod full of rainwater,is this possible?
If possible, how would i go about this task?
racecougar
Missouri
Assuming it's a 275 gallon tote, that's ~2300 lbs when full of water. You'll want something far more substantial than the tote cage as an elevated stand.
ericm
Southern Oregon
It's common to use IBC totes for firewood. Many people cut "doors" in one side to get the wood in and out. I have 10 of them. They have held up. I use a 4.5" grinder to cut the cage and a hole saw and reciprocating saw to cut up the bladders to make rain caps.
The bladder isn't designed to be filled with water outside the cage but if you cut the cage and the bladder a couple horizontal rungs down it will probably hold the reduced weight. Usually when I see them holding rain water they have some sort of collection system (like a roof) feeding water into them.
alfadan
Augusta, ks
I use three for my garden. They sit on cinder blocks, one on each corner. They shift around after the first filling. I didn't cut them, just a piece of gutter and some pvc pipe to fill through the hole.
Be aware that algae growth gets pretty bad in the sunlight and they start getting brittle.
racecougar
Missouri
Garden, though I actually did the math and I can pay $4 dollars and use the same amount of water if I just use my faucet! So not sure if I'll do it again next year.
Similar story here. It costs less than $3 to fill that tote each time.
bluedog225
Texas
True but you can add a gallon of molasses, fish stuff, light fertilizer, etc. Makes for easy application.
