Ice & water that’s been in storage
Chennig
Central MN
I just bought 6 new rolls of ice and water for my garage build.
But, a friend of mine said he has 6 rolls he is wanting to give away. The down side is that they have been sitting for 7 years.
7 years seems like a long time to sit and question if it’s worth the cost savings.
Thoughts?
techieman33
Kansas
Thoughts?
How was it stored?
The Cobbler
If it has been kept dry, I assume you have zero issues. if it broke down in a dry environment after 7 years, what would it do under a shingled roof?
if it unrolls & is pliable, I would use it
Copymutt
Colorado
Might try to partially unroll one roll. I wouldnt think its lost its functionality, but if exposed to heat and cold i’d want to be sure it hasn’t glued itself togetheir. Could be a great score, its not cheap.
mcbane
California
Am I misunderstanding something? In our home we keep ice in the freezer, and water in the refrigerator. But never for more than a couple of months.
After 7 years the flavor might not be the same. I’ve never eaten ice and water shield but I would want the taste to at least be worthy of one Michelin star.
Git
S Cal
https://gcpat.com/en/solutions/prod...ofing-underlayment/tl-0011-shelf-life-roofing
The shelf life of GCP underlayments (GRACE ICE & WATER SHIELD®, GRACE ICE & WATER SHIELD® HT, GRACE ULTRA™, GRACE SELECT™, Roof Detail Membrane™, GCP granular underlayment , TRI-FLEX® and TRI-FLEX® 15) is highly dependent on storage conditions. In general, these products should be stored in their original, unopened packaging at ambient temperatures between 40–90°F (5–32°C) under dry conditions. GCP self-adhered underlayments have optimum initial adhesion to the roof deck if used within one year from the date of manufacture.
With that being said, what would it hurt to have both on-site, try the old stuff and see how it sticks? At that point, you can decide which to go with
C
Chennig
Central MN
I'd suggest that the OP is either trolling or too dumb to be in a garage.
You can never take my LEGOs away my friend! Although they do taste good.....
May be worth the try.
He claims it was stored in his heated garage, I’m just hoping it was not right on his heated slab.
I just don’t want to be kicking myself 10-15 years down the road over trying to save a small amount(in comparison to the total garage cost).
LS6 Tommy
Northern NJ
:lol_hitti I was a little confused at first until he mentioned a "roll of ice".
Tommy
Bretny
Dutchess county NY
If its still flexable and sticky use it. No one is removing there roof to put new ice and water shield every 7 years around here. Also the sticky part of it is really just to aid in installing. The nails really hold things well.
Worsedog
Central FL
Well thank you for that genius observation. I'm sure that the OP has found it most enlightening. :headscrat
Hopefully you can lend your wisdom to anyone else with a question.:thefinger
79firebird
Victoria bc
i would use it. never know how long the stuff at the store has been in the warehouse or store. the local home depot has some and the date tag says 2004 where 2019
spudley
Northeast Wisconsin
For free I'd use it.
As stated, even if it isn't sticky the nails will hold it. Or to be safe, maybe a row of new stuff as the first course over the eave.
koditten
Midland, Michigan
Buy the new stuff and have it ready. Get the old stuff from your friend. If it is plenty sticky, use it and return the new stuff.
Better buy a case of beer to give to your friend as well. Its gonna be fine and he needs to be properly thanked.
