kd3pc.... I have not looked at the cost yet but they looked stone simple to work with... Kinda reminded me of Legos. As long as they are square and plumb on the footings I would think they would be not much different than laying a block foundation...? Sales guy at the home show said many people pour half the depth of the wall at a time to reduce the chance of a blow out in the form... That part doesnt really thrill me. Not sure if I like the idea of a seam/cold-joint in the basement wall....
Our house is ICF, and we love it! I did most of the work, with coaching from a local contractor who specializes in ICF. I rented bracing from him, and hired his crew to actually fill the forms. The filling and consolidation of the concrete are very important. Here's a link to my build thread:
http://countryplans.com/smf/index.php?topic=12170.0
Personally, I would pour conventional wall and frame with 2x4 inside and spray foam the wall and rim joist. Way less expensive and far better result imo.
Considering using ICF's for a new house build. Has anybody used them? Any tips? Things to look for? Pros and cons? Thanks...
I used Fox Blocks, and didn't have any issues with dimensions. Of course, mine is a much smaller house, and only two stories (basement and main floor). The only part of mine that took some thinking was creating the door and window openings. My walls came out within 1/4" straight/square/plumb/level. Part of this is due to having absolutely perfect footings. I glued my first course, and glued the corners. Fox sells a clip to hold the blocks together so they can't float or separate.
Done properly, the method is inherently airtight, which has been found to be a major contributor for energy loss. Concrete walls are a lot more likely to stay airtight than wood framing, which shrinks, warps, and wracks over time. Also, the thermal mass has a huge effect, but only at certain times of year. I was just reading a study that found that the R rating is true in winter and summer, but can run much higher during the shoulder seasons of spring and fall. It also makes a very strong, quiet house, and the walls are bullet proof, handy for the next zombie apocalypse!
I spent 6 years studying this stuff before deciding on ICF, and one of the reasons I went this route is that I'm 61 years old, and working alone, so ICF was a good way to go. I would have needed help for any other system.
ICF is a great system, avoiding form costs, but it really isn't very energy efficient.
The actually amount of insulation over an entire wall assembly is fairly low unless you go with a very thick wall.
Plus there is a lot of hype about 'equivalent' R values, which under most climates is bogus.
They are rated at least R-22 actual, which is similar to what you get with conventional. But then subtract thermal bridging. And the fact there is ZERO airflow (also an advantage for spray foam). It's not just in the R-value numbers.
Not sure at what point if any it's more economically viable, but I think saying it's not energy efficient is pretty inaccurate.
I will stand by that, or as mentioned you have a very thick wall.
XPS has an R value of about 4 per in. You would need 5.5" of foam, plus the concrete core usually 5.75" min, plus the interior and exterior finishes, another 1.5".
That is about a 13" wall min. and only R22.
A 13" wood framed wall, double staggered studs etc, would be far more energy efficient.
And you can make a wood framed home very air tight with attention to detail.
R-values are something of a moving target. The “steady state” R-value of a 10-inch-thick wall is between 7.7 and 8.2, according to ORNL tests.
Read more: http://www.greenbuildingadvisor.com/green-basics/insulated-concrete-forms#ixzz4dyAEyuq9
Concrete walls have lots of other positive points like hurricane resistant, basement walls, etc,,, but ICF judged as an insulated assembly isn't very energy efficient per inch.
Wondering how much trouble you had getting the permit for the project and who was the architect, I would like to build a icf home in Chicago
Do you know how contradictory that statement is?I think your usage of the term efficient is incorrect. While the R value numbers for a ICF wall would be considered low to a same thickness stick framed. The but efficiency of the ICF is far better. I heat a greater area with more comfort and less money than the same in stick frame.
I see your mathematical statement about efficiency “per inch”, but I’m not sure that’s a very meaningful measure. It might be in a very constrained urban situation – ICF construction would loose a foot of usable width on a small lot. In our City, a standard lot is 25’ wide and then we count down from there based on the wall assembly and any other needed set-backs.
My wife has built uber-efficient houses (with thick wooden walls) here in the City in addition to the ICF and the air sealing just doesn’t happen. The nature of the contracting business is such that someone will always cut the important air sealing “corners” when the boss isn’t looking.
R value is a measure of thermal resistance.
Are you comparing a new ICF home to some old, leaky, poorly insulated, low quality windows and doors and poorly constructed wood frame? If so it isn't a surprise that ICF is more comfortable.
Almost all the super energy efficient homes are wood framed, you simply can not get as energy efficient a building from ICF w/o very thick walls, and much higher construction costs.
5.75 inches (the concrete) of an ICF wall has basically zero R value.
Plus the 1.5 inches of stucco and plaster, which also are basically zero.
That is 7 plus inches of the wall with no thermal resistance.
What on a wood framed wall has zero R value? Nothing, maybe the stucco if it uses stucco.
Well measured by the inch, ICF isn't very energy efficient.
Measured by initial construction cost, ICF isn't very energy efficient either.
So by what standard do you want to measure energy efficiency?
And because of the wall thickness and weight you can't use std door frames, windows are deep set and a larger footing is required, all adding to the cost.
Air sealing can be done on wood frame, it isn't that hard and it can be done to where the house is too air tight and fresh air must be brought in.
Crappy workmanship is always an issue, poorly installed batt insulation drops the R value substantially. Many homes have R19 in the walls but because of poor installation the overall effective wall is R9.
Does that mean you shouldn't use batt insulation?
ICF can have other "values" as mentioned, but being energy efficient isn't one of them.
Really if you want a concrete walled home, the concrete should be precast where the wall design is much more efficient because of the plant controlled conditions, as in a thinner wall. And the hard, durable concrete should be on the outside protecting the soft, flammable, low melting temp foam from the elements, fire, woodpeckers etc...
Putting stucco over exterior foam just creates a soft base where the stucco can be easily damaged, especially the soft stucco used these days.
I have seen lots of thin EIFS where you literally can poke a hole through the finish with your finger.
You keep quoting R value but even that is a skewed test that artificially boost the on paper performance of fiberglass. The test is set at 70 degrees and a heat source is added to on side and it's timed how long the other side takes to raise a degree or two.
However fiberglass as the temp differential gets extreme(70 inside and 0 degrees out side for example) their will start a convection currents form and the actual performance pluments.
Wow.... It would seem to me that science and data would have been able to figure out a true R between ICFs and a 2x4" by now!
